I found an article that it is possible to integrate suricata allerts into ntopng:
https://www.ntop.org/guides/ntopng/advanced_features/suricata.html
Wouldn’t this a nice feature in Nethserver?
At the moment, the implementation it’s a little bit hacky and I’m not sure it worth the effort: IMO evebox is much more clear.
Also I do not know if it can work with ntopng 4.
Maybe you can try the suggestions from the talk using some template-custom and report back.
