Ntopng configuration to enable NIC cards
Ntopng is able to monitor only one Nic… i.e eth0
not able to change or add other inerfaces from ntop portal.
is there any configuration file I can edit to enable eth1 and and eth2
How to enable multiple NIC cards monitoring?
Default configuration will enable all cards except for the red ones.
If you want to change this behavior, just create a template custom for this fragment:
/etc/e-smith/templates/etc/ntopng/ntopng.conf/10base
Thanks, I got it.
Added --interface eth1 in ntopng.conf file and it is ready.
