giacomo
(Giacomo Sanchietti)
June 16, 2020, 2:16pm
1
ntopng 4 has been integrated into NethServer and replaces old ntopng 3.
This is how ntopng 4 looks like with dark theme:
The new implementation brings a new Cockpit UI.
In the dashboard you can easily spots hosts which are doing most of the network traffic:
And the settings page:
Before releasing the update, we hope to have further testing, especially when upgrading existing installations.
What you should check:
after the upgrade the /var/tmp/ntopng must not exists and ntopng should display also data collected before the update
The service must restart correctly after the update (and if it was active at the time of the update it must continue to run without the need for manual restarts)
To install it:
yum install --enablerepo=nethserver-testing \*ntopng\*
Kudos for the great work to @andre8244 @davide_marini and @edoardo_spadoni !
Please try it and give us feedback
Hi Giacomo,
I never used it before. Quite nice.
For new user, you should add a note about starting it after installation:
# systemctl start ntopng
I didn’t update yet.
Michel-Andre
Hi Giacomo,
I updated:
# yum update -y --enablerepo=nethserver-testin
# wget http://packages.ntop.org/centos-stable/ntop.repo -O ntop.repo
# rpm -ivh https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
Erreur : Paquet : ntopng-data-4.0.200617-9264.noarch (ntop-noarch)
Requiert : geoipupdate
Vous pouvez essayer d'utiliser --skip-broken pour contourner le problème
Vous pouvez essayer d'exécuter : rpm -Va --nofiles --nodigest
# yum update -y --skip-broken
# systemctl restart ntopng
# systemctl status ntopng
# reboot
# CentOS/RedHat Stable Builds ******************
# http://packages.ntop.org/centos-stable/
# yum erase zeromq3
# yum clean all
# yum update
# yum update --skip-broken
# yum install pfring-dkms n2disk nprobe ntopng cento
# Migrate the data directory in ntopng/nEdge *****
# https://www.ntop.org/support/faq/migrate-the-data-directory-in-ntopng/
# systemctl stop ntopng
# rmdir /var/lib/ntopng
# mv /var/tmp/ntopng /var/lib/ntopng
# chown -R ntopng:ntopng /var/lib/ntopng
Michel-André
giacomo
June 18, 2020, 6:40am
5
Thank you for testing Michel, but you should not install it from the official repo. It’s a normal NS package, and, after install, you should enable the service from the UI.
So, if you want to install it from the command line, follow the instructions in the post above.
looks like i may need that for my home network.
my isp provided ips eep getting blacklisted, and nothing else is running on my home…
which is weired. need to see whats happening, hope it can help to identify the issue
Hi Giacomo,
# cat /etc/nethserver-release
NethServer release 7.6.1810 (final)
I never use Cockpit because it’s still in Beta .
In French, notice the cut in: Nom d’utilisateur
# yum install --enablerepo=nethserver-testing \*ntopng\*
Installé :
nethserver-ntopng.noarch 0:2.1.3-1.ns7 ntopng.x86_64 0:3.3.180109-3804
ntopng-data.noarch 0:3.3.180109-3804
Dépendances installées :
hiredis.x86_64 0:0.12.1-2.el7 libnetfilter_queue.x86_64 0:1.0.2-2.el7_2
libsodium.x86_64 0:1.0.18-1.el7 numactl.x86_64 0:2.0.9-7.el7
openpgm.x86_64 0:5.2.122-2.el7 pfring.x86_64 0:7.1.0-1681
zeromq.x86_64 0:4.1.4-6.el7
Terminé !
â—Ź ntopng.service - ntopng high-speed web-based traffic monitoring and analysis tool
Loaded: loaded (/etc/systemd/system/ntopng.service; disabled; vendor preset: disabled)
Active: active (running) since jeu. 2020-06-18 09:45:42 EDT; 3s ago
# yum update -y --enablerepo=nethserver-testing
No packages marked for update
No packages marked for update * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
# reboot
Active: inactive (dead)
Active: active (running) since jeu. 2020-06-18 10:12:11 EDT; 3s ago
Modules complémentaires chargés : changelog, fastestmirror, nethserver_events
* epel: mirror.dst.ca
In cockpit login page: Nowhere to change language…
0 update available:
# yum update -y --enablerepo=nethserver-testing \*ntopng\*
Still => No packages marked for update * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
That is why I downloaded and installed.
Where did I go wrong ?
Michel-André
giacomo
June 18, 2020, 3:19pm
8
7.6 is EOL since 2 years, you need to update to 7.8
carsten
(Carsten Härle)
June 30, 2020, 11:34am
9
I installed a GeoIP license but I see no geo-ip information nor a host geo map. Is there anything else to activate?
giacomo
June 30, 2020, 12:14pm
10
I do not know, I never tried GeoIP support on ntopng.
Maybe @davide_marini knows something more about it.
pike
(Michael Kicks)
July 1, 2020, 10:50am
11
GeoIP db now not GPL Licensed anymore…
I would convert this topic to an #announcements
I work on it and publish next week
carsten
(Carsten Härle)
July 3, 2020, 6:40pm
13
I found it (it seems to need a restart). Works fine with the free license, which has to be registered.
