Grafana Issue:
If I define only the host name, the site is not reachable
The field should labeled with “FQDN”
Grafana Issue:
hello really not a migration tutoriel but this is a starting point
how to create a user inside mariadb container, first on the node ssh to the userLinux
# connect to mariadb1 (module_id)
ssh mariadb1@localhost
# connect to the mysql container as root
podman exec -ti mariadb-app mysql
# create the database and grant user to all from any IP (external port is closed to 127.0.0.1)
MariaDB [(none)]> CREATE DATABASE IF NOT EXISTS mydatabase;
MariaDB [(none)]> grant all privileges on mydatabase.* to username identified by 'password';
MariaDB [(none)]> flush privileges;
MariaDB [(none)]> exit
add data to the database from a mysql dump
podman exec -i mariadb-app mysql < toto.sql
the example content of toto.mysql, like you can see the user is able to connect from any host, this is a mandatory because we connect from outside the container, but the tcp port
is restricted to localhost
CREATE DATABASE if not exists foo;
CREATE USER if not exists 'foo' IDENTIFIED BY "foo";
GRANT ALL PRIVILEGES ON foo.* TO 'foo';
FLUSH PRIVILEGES;
use foo;
CREATE TABLE IF NOT EXISTS pages (
id INT(4) UNSIGNED NOT NULL AUTO_INCREMENT PRIMARY KEY,
title VARCHAR(30),
content TEXT,
INDEX(title)
) engine=InnoDB;
INSERT IGNORE INTO pages VALUES (1, 'Bienvenue', 'Bienvenue ');
then on the remote host running the web server send all local files by scp (login 9001 password 9001 for the first vhost you have created inside the ns8-webserver )
the default port is tcp 3092, think to enable the external access, the 9001 is the login of the first vhost
sftp -P 3092 9001@r1.rocky9.org
# move to you local web folder and cp everything to the vhost of NS8
lcd Téléchargements/wordpress-6.2.2-fr_FR/wordpress/
sftp> put -r *
