NS8 Webserver: problems with CA verification
NethServer Version: NS8
Module: Webserver
Hi all,
I’m getting this error while I’m trying to send emails or get contents from other external urls in ssl or https.
2026-01-09 00:02:04 Connection failed. Error #2: stream_socket_client(): SSL operation failed with code 1. OpenSSL Error messages:error:16000069:STORE routines::unregistered schemeerror:80000002:system library::No such file or directoryerror:16000069:STORE routines::unregistered schemeerror:80000002:system library::No such file or directoryerror:16000069:STORE routines::unregistered schemeerror:80000002:system library::No such file or directoryerror:0A000086:SSL routines::certificate verify failed [/var/www/html/9001/wp-includes/PHPMailer/SMTP.php line 422]
How can I solve this? The system give me this link: PHP: OpenSSL changes in PHP 5.6.x - Manual
Thank you in advance
Could it be a regression from the last webserver update? Does it work with the previous version?
Does the site have a valid certificate?
PHP 5.6 is quite old.
Could you please explain what exactly you are using here? is it a WP site/plugin?
So I can try to reproduce the issue.
Maybe it helps to change the mail configuration to use the domain name instead of the IP?
Hi @mrmarkuz
Also with 1.3.0 doesn’t work.
Yes, both: the site on webserver and the mail server I’m trying to reach.
I’m using WP Mail SMTP and test the mail send, but you can reproduce also with a simple php script with file_get_contents function (after enabling allow fopen). You can try to reach any https site and you get this error.
It’s already with the name.
with ns8-lamp I wrote a script to test to send email, do not know if it can help for test or to try to reproduce
If you try to run this script:
<?php
echo file_get_contents("https://download.q-i.it/docs/miniwre/latest/en_version.txt");
It should return a version number, but at the moment it return the above error.
tls1.3 is the last tls encryption :-?
It’s hosted on other ns8 webserver, but the same problem with ns8 mail module
I think it’s about a wrong openssl config.
Here is an insecure workaround:
<?php
$options=array(
    "ssl"=>array(
        "verify_peer"=>false,
        "verify_peer_name"=>false
echo file_get_contents("https://download.q-i.it/docs/miniwre/latest/en_version.txt", false, stream_context_create($options));
The better method would be to configure the right ca cert but I didn’t find it yet.
Maybe related:
I’ve found this solution, but with WordPress It doesn’t work:
stream_context_set_default([
    'ssl' => [
        'cafile' => '/var/www/html/9004/cacert.pem',
        'verify_peer' => true,
$data = file_get_contents("https://your-url.com");
But I think we need to fix this via .ini file.
hum, we use a dockerfile to build our container since we have moved from bitnami, I bet we miss to install the deb that is responsible of the key and known certification authority in debian, need to check
root@webserver:/var/www/html# php toto.php
Ver. 2.07root@webserver:/var/www/html#
podman exec -ti php8.4-fpm bash
apt update
apt install ca-certificates
it will disapear after any container reboot for now, can you test @federico.ballarini
I can confirm that the php script is working after installing ca-certificates in the php container.
Yes! I confirm that also mail send works now!
Thanks a lot @stephdl and @mrmarkuz! You are special!
coming soon
