NS8 Something went wrong
NethServer Version: NS8
Module: Doamin and users
NS8 installed on Debian is giving an unexpected error again.
Users cannot log in to SOGo or anywhere else. I went to Domain and users and the error shown in the image appears.
The system log shows the following:
2025-04-08T16:44:38+02:00 [1:ldapproxy1:ldapproxy] 2025/04/08 14:44:38 [error] 28#28: *135579 connect() failed (113: Host is unreachable) while connecting to upstream, client: 127.0.0.1, server: 127.0.0.1:20001, upstream: "192.168.1.227:636", bytes from/to client:0/0, bytes from/to upstream:0/0
2025-04-08T16:44:38+02:00 [1:ldapproxy1:ldapproxy] 2025/04/08 14:44:38 [error] 28#28: *135581 connect() failed (113: Host is unreachable) while connecting to upstream, client: 127.0.0.1, server: 127.0.0.1:20001, upstream: "192.168.1.227:636", bytes from/to client:0/0, bytes from/to upstream:0/0
2025-04-08T16:44:38+02:00 [1:mail1:dovecot] auth-worker(48): Error: ldap(/etc/dovecot/userdb.conf.ext): Connection lost to LDAP server, reconnecting
2025-04-08T16:44:38+02:00 [1:ldapproxy1:ldapproxy] 2025/04/08 14:44:38 [info] 25#25: *135583 client 127.0.0.1:45846 connected to 127.0.0.1:20001
2025-04-08T16:44:38+02:00 [1:mail1:dovecot] auth-worker(60): Error: ldap(/etc/dovecot/userdb.conf.ext): Connection lost to LDAP server, reconnecting
2025-04-08T16:44:38+02:00 [1:ldapproxy1:ldapproxy] 2025/04/08 14:44:38 [info] 26#26: *135585 client 127.0.0.1:45856 connected to 127.0.0.1:20001
A week ago, I changed my router, etc., so I changed the server’s IP address from DHCP to static and it worked fine until the weekend, but since yesterday it’s been showing the error.
What could be the reason for this and how can I fix it?
Thanks for your help
You may need to set the samba ip to the new ns8 ip:
Thank you for your help again @mrmarkuz I can always count on your help. Thank you.
I thought it might be an IP address problem, but the error didn’t appear until Sunday night when the server restarted.
I was looking for a solution but I didn’t think the solution would be with the Nethserver 7 migration. I’ll make a note of it.
Thank you
