NS8 - SMTPUTF8 is required, but was not offered by host
Strange problem today : a particular email isn’t getting delivered into my mailbox. rspamd sees it and doesn’t classify it as spam.
What could be wrong ? For the record that’s the same server with which I had problems yesterday trying to configure a smarthost - may or may not be related.
The lines related to this mail in the maillog :
I see this : SMTPUTF8 is required, but was not offered by host mail.gaillet.be[
2025-01-17T12:25:04+01:00 [1:mail1:postfix/smtpd] 56167101856: client=o111.p13.mailjet.com[87.253.238.111]
2025-01-17T12:25:04+01:00 [1:mail1:postfix/cleanup] 56167101856: message-id=<42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@mailjet.com>
2025-01-17T12:25:04+01:00 [1:mail1:rspamd] (normal) <561671>; task; rspamd_message_parse: loaded message; id: <42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@mailjet.com>; queue-id: <56167101856>; size: 12387; checksum: <fcd2410851e6d39362c1bceb0c45a96b>
2025-01-17T12:25:04+01:00 [1:mail1:rspamd] (normal) <561671>; task; rspamd_task_write_log: id: <42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@mailjet.com>, qid: <56167101856>, ip: 87.253.238.111, from: <42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@a1007401.bnc3.mailjet.com>, (default: F (no action): [-1.11/15.00] [BAYES_HAM(-2.99){99.99%;},SUBJECT_NEEDS_ENCODING(1.00){},URI_COUNT_ODD(1.00){3;},FORGED_SENDER(0.30){no-reply@bayam.tv;42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@a1007401.bnc3.mailjet.com;},R_DKIM_ALLOW(-0.20){bayam.tv:s=mailjet;},R_SPF_ALLOW(-0.20){+ip4:87.253.232.0/21;},MIME_BASE64_TEXT(0.10){},MIME_GOOD(-0.10){multipart/alternative;text/plain;},HAS_LIST_UNSUB(-0.01){},MX_GOOD(-0.01){},ARC_NA(0.00){},ASN(0.00){asn:200069, ipnet:87.253.232.0/21, country:FR;},DKIM_TRACE(0.00){bayam.tv:+;},DMARC_DNSFAIL(0.00){bayam.tv : server fail;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){no-reply@bayam.tv;42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@a1007401.bnc3.mailjet.com;},HAS_REPLYTO(0.00){no-reply@bayam.tv;},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},RBL_SENDERSCORE_REPUT_8(0.00){87.253.238.111:from;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_ZERO(0.00){0;},RCVD_IN_DNSWL_NONE(0.00){87.253.238.111:from;},REPLYTO_EQ_FROM(0.00){},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 12387, time: 493.883ms, dns req: 51, digest: <fcd2410851e6d39362c1bceb0c45a96b>, rcpts: <me@gaillet.be>, mime_rcpts: <me@gaillet.be>
2025-01-17T12:25:04+01:00 [1:mail1:postfix/qmgr] 56167101856: from=<42a95b18.AXMAAF3rsbEAAAAAAAAAA8crgy0AAYCr2O4AAAAAAA9fKQBnij4P@a1007401.bnc3.mailjet.com>, size=12829, nrcpt=1 (queue active)
2025-01-17T12:25:04+01:00 [1:mail1:postfix/lmtp] 56167101856: to=<matthieu@gaillet.be>, relay=mail.gaillet.be[/var/lib/umail/lmtp], delay=0.68, delays=0.64/0.01/0.03/0, dsn=5.6.7, status=bounced (SMTPUTF8 is required, but was not offered by host mail.gaillet.be[/var/lib/umail/lmtp])
2025-01-17T12:25:05+01:00 [1:mail1:postfix/bounce] 56167101856: sender non-delivery notification: F0019101A3B
2025-01-17T12:25:05+01:00 [1:mail1:postfix/qmgr] 56167101856: removed
Other mails are delivered, only the mails from this particular sender aren’t. :thinking:
Thanks for helping…
It is not correctly encoded for Dovecot LMTP agent.
It triggers a bounce, ugly.
IIUC Postfix accepts the UTF-8 character but Dovecot does not. To work around the issue, you could try to disable SMTPUTF8 in Postfix’s configuration. See Postfix Configuration Parameters
smtputf8_enable = no
Put that line in a custom file, as explained here: ns8-mail/README.md at main · NethServer/ns8-mail · GitHub
Working. I suppose this should be considered as a bug ?
Thanks !!
if you can help to test it
hello pagaille would it be possible to test the package to see if we have fixed the issue ?
Sure, will do. ASAP :grimacing:
The target is mail:1.5.2-dev.3. Please use the UI to upgrade it
  • Disabled the manual fix : ok
  • Tested with an offending mail to confirm that the problem was still there : ok
  • Applied the fix
  • tested again : working ! ✓
