Hi, tks for reply, see:
[root@nlserver01 ~]# journalctl -e -t rspamd
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule SURBL_MULTI: checks: alive,helo,dkim,emails,replyto,urls,rdns
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule SURBL_HASHBL: checks: alive,selector
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; lua_maps.lua:290: reuse url for complex map definition p1tsamp7: RBL url whitelist for RSPAMD_URIBL
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1126: added URL whitelist for RBL RSPAMD_URIBL
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule RSPAMD_URIBL: checks: alive,dkim,emails,urls
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; lua_maps.lua:290: reuse url for complex map definition p1tsamp7: RBL url whitelist for URIBL_MULTI
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1126: added URL whitelist for RBL URIBL_MULTI
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule URIBL_MULTI: checks: alive,helo,dkim,emails,replyto,urls,rdns
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule MAILSPIKE: checks: alive,user,local,ip
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule RBL_VIRUSFREE_UNKNOWN: checks: alive,user,local,ip
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; rbl.lua:1180: added rbl rule BLOCKLISTDE: checks: alive,user,local,ip,received
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module rbl from /usr/share/rspamd/plugins/rbl.lua; digest: 007a55d1>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; lua_redis.lua:603: use default Redis settings for replies
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module replies from /usr/share/rspamd/plugins/replies.lua; digest: >
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; lua_redis.lua:603: use default Redis settings for reputation
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module reputation from /usr/share/rspamd/plugins/reputation.lua; di>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_config_is_module_enabled: lua module rspamd_update is disabled in the configuration
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module settings from /usr/share/rspamd/plugins/settings.lua; digest>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module spamassassin from /usr/share/rspamd/plugins/spamassassin.lua>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_config_is_module_enabled: lua module spamtrap is disabled in the configuration
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module spf from /usr/share/rspamd/plugins/spf.lua; digest: 864ad0d3>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; trie.lua:169: no tries defined
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module trie from /usr/share/rspamd/plugins/trie.lua; digest: d75d7b>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; lua_redis.lua:603: use default Redis settings for url_redirector
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; lua; url_redirector.lua:379: no redirector_hosts_map option is specified, disabling module
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module url_redirector from /usr/share/rspamd/plugins/url_redirector>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/etc/rspamd/local.d/maps.d/spf_dkim_whitelist.inc.local’ is not found,>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/var/lib/rspamd/spf_dkim_whitelist.inc.local’ is not found, but it can>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/etc/rspamd/local.d/maps.d/dkim_whitelist.inc.local’ is not found, but>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/var/lib/rspamd/dkim_whitelist.inc.local’ is not found, but it can be >
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/etc/rspamd/maps.d/dkim_whitelist.inc’ is not found, but it can be loa>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/etc/rspamd/local.d/maps.d/spf_whitelist.inc.local’ is not found, but >
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/var/lib/rspamd/spf_whitelist.inc.local’ is not found, but it can be l>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/etc/rspamd/maps.d/spf_whitelist.inc’ is not found, but it can be load>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/etc/rspamd/local.d/maps.d/dmarc_whitelist.inc.local’ is not found, bu>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_map_parse_backend: map ‘/var/lib/rspamd/dmarc_whitelist.inc.local’ is not found, but it can be>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) ; cfg; rspamd_init_lua_filters: init lua module whitelist from /usr/share/rspamd/plugins/whitelist.lua; dige>
Aug 19 16:58:30 nlserver01 rspamd[2266]: (main) rspamd_url_init: start compiling of 9628 TLD suffixes; it might take a long time
Aug 19 16:58:32 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:32 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
[root@nlserver01 ~]# journalctl -e _UID=$(id -u mail4)
Aug 19 16:58:35 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:35 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
Aug 19 16:58:38 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:38 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
Aug 19 16:58:41 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:41 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
Aug 19 16:58:44 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:44 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
Aug 19 16:58:47 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:47 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
Aug 19 16:58:50 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
Aug 19 16:58:50 nlserver01 rspamd[2274]: /usr/bin/bash: line 1: /dev/tcp/127.0.0.1/11334: Connection refused
Aug 19 16:58:53 nlserver01 rspamd[2274]: /usr/bin/bash: connect: Connection refused
