So I add a user. Not sure what I can do with him as he can’t log on at a terminal. He can’t log on to the web page, even after I promote him to a Domain Admin.
Going back to a terminal, root can no longer log on to administer the OS. *** Update *** Ignore this, stupid operator error.
Create a Samba share. Go over to my Windows, and yes, it can be seen:
Try and connect to it. Ooops:
Finished playing around, so let’s shut down the VM. Oh dear, there’s no shutdown to be found on the Admin web pages and I can’t log in via a terminal any more.
Users are available only for NS8 modules, they do not have access to the underlying system: so no SSH access.
That’s strange, it should not be related: NS8 does not change PAM nor SSH configuration.
I will try to reproduce.
How did you enter the credentials? If the Windows machine is not joined to the AD, I think you should enter the full credentials with the domain.
Maybe @davidep has already did some tests on this.
NS8 is not meant to manage the distro. You could install Cockpit to access such operations from a web UI.
Using your examples: \\server.nethserver.org\ShareIt
Throws this without asking for password:
In a Windows command window (obviously using “my” hostname)"
C:\Users\Eddie>ping server.nethserver.org
Pinging server.nethserver.org [192.168.0.145] with 32 bytes of data:
Reply from 192.168.0.145: bytes=32 time<1ms TTL=64
Next, using this: \\192.167.0.145\ShareIt
I get the correct password prompt.
At that prompt, if I use: giacomo@nethserver.org
I get a message saying the password is wrong. But using: giacomo
Worked correctly and presented the shared folder.
