Install Patchmon through the Software Center (actual Patchmon version v1.3.4)
Todo:
Test update via Software Center
LE tests
test Force https
Test backup/restore
Readme and docs on github
Probably something else
Note: Patchmon is relatively young and rapidly evolving. I built the module using @kemboielvis22’s module generator and then adapted it because it was quite complex (at least for me).
I also have limited experience with GitHub and managing releases through the Software Center, so for now please install it only in testing environments.
Happy to keep growing the community of developers for Nethserver.
THis makes sure we are able to cater for a diverse pool of needs for different businesses looking to utilize NS
Wow, thanks for the tests and especially for the fixes — I’ll try to study them better for next time! Thanks… just merged
As for the generator, I’ll write directly in the dedicated thread.
Thanks again.
I’ve just released an update for the module (with PatchMon v1.3.6), and it should be upgradable from the Software Center. Since it’s the first one I’ve published, let me know if you run into any issues. Thanks!
I’ve just updated the module with Patchmon version 1.3.7.
Please note the potential issue with agent auto-updates. Here is the link to the Patchmon changelog:
note: There are quite a few changes and new env vars in this release. I still need to add the timezone configuration (I’ll probably inherit it from the host) and figure out how to handle things like rate limiting and the OIDC-related settings.
Yes, unfortunately that was a known issue when version 1.3.7 was released, the link is a few posts above: Ns8-patchmon testing - #12 by dz00te
And it was quite annoying. When I upgraded to 1.3.7, I also had to restart all the agents.
Regarding the missing update notification, I was looking at one of your screenshots from Pegaprox thread. It might have been installed from the command line using the latest tag, so repository versions wouldn’t be reported as updates.
Sorry about that, in effect both Patchmon and Pegaprox are still under active development. In any case, thanks for testing the module!
