Ns8 on raspberry pi 4?
This is because you’re still pointing the installation image to the official samba one!
Changing this line with your image should make everything work fine.
yes much more success now :bouquet:
Samba count provider seems to be running!
Still quite some errors in the logs, (see end of gist) as said was able to add an user.
The initial installation of the node pulls in two images from ghcr.io/nethserver/ (loki and ldapproxy),
$  podman image list --all
REPOSITORY                    TAG         IMAGE ID      CREATED       SIZE
ghcr.io/nethserver/traefik    2.1.0       39961d94bd8d  9 days ago    132 kB
ghcr.io/tbaile/core           main        a68ba2b77818  10 days ago   139 MB
ghcr.io/tbaile/redis          main        6df53c5d2d03  10 days ago   42.8 MB
ghcr.io/tbaile/rsync          main        2b3a46ae2be6  10 days ago   9.48 MB
ghcr.io/tbaile/restic         main        f287a15011df  10 days ago   86.1 MB
ghcr.io/nethserver/ldapproxy  1.0.0       22e5405803da  2 months ago  26.8 kB
docker.io/grafana/promtail    2.9.2       c04c05a00c6c  2 months ago  193 MB
ghcr.io/nethserver/loki       1.0.0       9ccb9414fb0a  6 months ago  22.2 kB
that can no be right … or is it?
Modules are actually separated this way:
There’s the MODULE IMAGE, which contains the following files:
  • the imageroot of the image (systemd services, cluster hooks for actions, configuration…)
  • module own UI, the same UI that helps you configure the module
  • additional can be found here
This images should be “arch-less” (unless, like the core, has binaries), and can be downloaded by every client despite the architecture.
This is not the case for the images that are used to run the actual software, usually specified in the images label of the image.
The “running” images, often come directly from the companies, and they most likely already have a ARM version built, which podman automatically pulls and runs. This is true for the traefik instance that you’re using to serve the main UI.
This comes by a per-module basis, if a module just uses the base image from official sources then yes, the module is installed correctly and the arm version of the container is happily running in the background.
If for necessities the container needs to be customized heavily (I.E. installing additional software) then you need to build the container for all the architectures that you want it available for. (this second case is exactly why building samba provides two containers, the module container and the runtime container)
Additional info will be probably available during Fosdem :speak_no_evil:
NDA sighted…
Thanks for the extensive explanation!
And I will be patient now :innocent:
Let’s give this a little kick…. Just curious what the current situation is. Pi 5 is out and other more powerfull/capable ARM hardware.
