etique57
(Etienne)
1
Hello,
I installed Debian netinstall 12.5, without selecting any additional software during the installation process (one of the last screens).
When I ran the install script command (after installing curl), I ran into the following error in the final script:
ssh-keygen command not found
I installed openssh-client and relaunched the script, which went smoothly to the end.
I guess it’d be necessary to make sure openssh-client is installed.
Thanks a lot for you work!
Etienne
davidep
(Davide Principi)
2
Thank you Etienne.
As alternative, the ssh-keygen requirement can be dropped. I think it is a pre-stable legacy.
davidep
(Davide Principi)
3
This issue fix has been merged and is available for testing in core 2.8.0-dev.2.
To install the next core testing release on a clean Debian 12:
bash install.sh ghcr.io/nethserver/core:2.8.0-dev.2
Check the bug was fixed
