When changing the FQDN of a node the file ‘/etc/motd.d/api-server’ is not regenerated with the correct FQDN value.
Hi LayLow, thank you for pointing it out.
The file is usually generated when api-server
is started.
Please try this workaround:
systemctl restart api-server
Or reboot the system.
Filed a card here
