NS8: Minor Display Issues
Couple of minor display issues I’ve spotted.
Every so often, my App Launcher loses it’s icons and shows this:
The Disk details on Node is showing 1 disk twice:
I only have 3 mounted disks:
/dev/sda5       9.0G  5.9G  3.1G  66% /
/dev/sda2       994M  363M  632M  37% /boot
/dev/sda1       100M  7.0M   93M   7% /boot/efi
Cheers.
I saw this in my tests and I think it could be a browser/cache issue, after reloading the page the symbols should be shown correctly.
I think the second one shows the relevant mountpoints (check all mounts by executing mount) and two of them are on the same disk.
Maybe it’s possible to setup a separate disk for the containers? In that case it would make sense.
Thank you for reporting, I’ve added 2 cards:
@EddieA can you confirm?
It depends which page (left side menu) you are on when you do the refresh. Some do not refresh the application icons, but being on Cluster Status did.
Cheers.
the partition you get more is an overlayFs for the storage of root container mounted to /var/lib/containers/storage/overlay. We plan to hide it
