Just out of curiosity if I did a migration. How would Meshcentral factor in to a NS8 migration. Will NS8 actually migrate it? or would I need to backup the data directories like Meshcentral videos tells you to do then copy them to the new install on NS8?
i think migration though possible, due to the fact that a database is used for the agents, might be abit more tricky.
this is because, we are also relying on URL of meshcentral for the agents on the corresponding servers. o, unless you might also be looking to utilizing the same domain FQDN, then it might not work even after migration.
In my tests with Rocky Linux on Proxmox I needed to set the VM CPU to “host” to make mongodb work, check out GitHub - mrmarkuz/ns8-meshcentral for more info.
