Ns8-lamp needs testers
I think I know why!!!
renamed to
apache2-app
readme modified, the backup is fixed, next release soon
backup was running well
:+1:
Hi @stephdl - next finding:
Within my WordPress Plugin “WP-Optimize” I found:
**Error: Unable to Check browser cache.** We encountered a problem while checking if browser cache is enabled.
We successfully updated your .htaccess file. But it seems one of Apache modules - mod_expires or mod_headers is not active.
That are the corresponding .htaccess entires
# BEGIN WP-Optimize Browser Cache
<IfModule mod_expires.c>
	ExpiresActive On
	ExpiresByType text/css "access 1 year 1 day"
	ExpiresByType text/html "access 1 year 1 day"
	ExpiresByType image/gif "access 1 year 1 day"
	ExpiresByType image/png "access 1 year 1 day"
	ExpiresByType image/jpg "access 1 year 1 day"
	ExpiresByType image/jpeg "access 1 year 1 day"
	ExpiresByType image/webp "access 1 year 1 day"
	ExpiresByType image/x-icon "access 1 year 1 day"
	ExpiresByType application/pdf "access 1 year 1 day"
	ExpiresByType application/javascript "access 1 year 1 day"
	ExpiresByType text/x-javascript "access 1 year 1 day"
	ExpiresByType application/x-shockwave-flash "access 1 year 1 day"
	ExpiresDefault "access 1 year 1 day"
</IfModule>
<IfModule mod_headers.c>
	<filesMatch "\.(ico|jpe?g|png|gif|webp|swf)$">
		Header set Cache-Control "public"
	</filesMatch>
	<filesMatch "\.(css)$">
	</filesMatch>
	<filesMatch "\.(js)$">
		Header set Cache-Control "private"
	</filesMatch>
	<filesMatch "\.(x?html?|php)$">
		Header set Cache-Control "private, must-revalidate"
	</filesMatch>
</IfModule>
#Disable ETag
FileETag None
Unfortunately, the settings are lost with every reboot.
Likewise, the changes to
/etc/mysql/conf.d/mysql.cnf
In the state files the files are not there ?
runagent -m lamp1
Check in the conf.d/ folder
I cannot reproduce, could you explain what you did
[root@R1 ~]# runagent -m lamp1
runagent: [INFO] working directory: /home/lamp1/.config/state
[lamp1@R1 state]$ tree
├── CACHEDIR.TAG
├── agent.env
├── apitoken.cache
├── conf.d
│   ├── mysql.cnf
│   └── mysqldump.cnf
├── discovery.env
├── environment
├── initdb.d
├── password.env
└── smarthost.env
2 directories, 9 files
[lamp1@R1 state]$ vim conf.d/mysql.cnf
[lamp1@R1 state]$ cat conf.d/mysql.cnf
[mysql]
# toto
[lamp1@R1 state]$ systemctl restart --user lamp
[mysql]
# toto
[lamp1@R1 state]$ podman exec -ti apache2-app bash
root@lamp:/# cat /etc/mysql/
conf.d/          debian-start     debian.cnf       mariadb.cnf      mariadb.conf.d/  my.cnf           my.cnf.fallback
root@lamp:/# cat /etc/mysql/conf.d/mysql
mysql.cnf      mysqldump.cnf
root@lamp:/# cat /etc/mysql/conf.d/mysql.cnf
[mysql]
# toto
root@lamp:/#
root@lamp:/# nano /etc/mysql/conf.d/mysql.cnf
[mysql]
# toto
#titi
root@lamp:/# exit
exit
[mysql]
# toto
#titi
[mysql]
# toto
#titi
[lamp1@R1 state]$
this is true, we miss the module
root@lamp:/# apachectl -M | grep expires
apachectl -M | grep headers
root@lamp:/# apachectl -M | grep headers
root@lamp:/# a2enmod headers
Enabling module headers.
To activate the new configuration, you need to run:
  service apache2 restart
root@lamp:/# a2enmod expires
Enabling module expires.
Usage: /usr/sbin/apachectl start|stop|restart|graceful|graceful-stop|configtest|status|fullstatus|help
       /usr/sbin/apachectl <apache2 args>
       /usr/sbin/apachectl -h            (for help on <apache2 args>)
root@lamp:/# apachectl restart
 headers_module (shared)
 expires_module (shared)
root@lamp:/# apachectl -M | grep proxy
 proxy_module (shared)
 proxy_http_module (shared)
it should be fixed with the new version
regarding this post, Ns8-lamp needs testers - #22 by stephdl
I changed the /etc/mysql/conf.d/mysql.cnf within the lamp2 container in a second attempt, because the mysql statement did not produce a persistent result.
But the changed file is missed after reboot.
I will wait for…
Another question or request from a non-command-line-wizard…
Could you integrate mc in your lamp (or other?) apps?
It also would help if you could integrate an alias for la -lsaph like ls -x
I make typos every time… :frowning:
please demonstrate it like I did :stuck_out_tongue:
root@mdol-nethserver:~# runagent -m lamp2
runagent: [INFO] working directory: /home/lamp2/.config/state
lamp2@mdol-nethserver:~/.config/state$
amp2@mdol-nethserver:~/.config/state$ tree
bash: tree: command not found
lamp2@mdol-nethserver:~/.config/state$ systemctl restart --user lamp
lamp2@mdol-nethserver:~/.config/state$ cat conf.d/mysql.cnf
[mysql]
quick
quote-names
max_allowed_packet	= 64M
lamp2@mdol-nethserver:~/.config/state$ podman exec -ti apache2-app bash
cat: /etc/mysql/: Is a directory
cat: /etc/mysql/conf.d/mysql: No such file or directory
[mysql]
quick
quote-names
[mysql]
quick
quote-names
#titi
exit
[mysql]
quick
quote-names
#titi
[mysql]
quick
quote-names
#titi
hope, it helps
what do you expect the file is there and the content is inside…
I am also wondering.
But I had a cp /etc/mysql/conf.d/mysql.cnf /etc/mysql/conf.d/mysql.cnf_org executed before and the backup file disappeared.
In any case, the setting to 64M is not evaluated after a reboot.
It is true and expected. The bck file is not a file that could survive the reboot
Show me the evidence please before and after the reboot
It’s realy easy.
Matomo tells me in diagnostics:
Changing the etc/mysql/conf.d/mysql.cnf has no positive effect, the error message persists
Using the mysql command you suggested makes the error go away for the current session, but the error message reappears after a reboot.
In the meantime, I have identified another really big problem.
I noticed it a lot when using my script (webtrees) that I use alongside WordPress. That’s why I initially assigned it to this as the cause and addressed it in the forum there.
However, the analysis of the server logs shows that the error is not only caused by this script, but also by the WorpPress page alone.
It turns out that the following scripts / asssets trigger error 403:’
  • /phpgedview/calendar.php?
  • /phpgedview/famlist.php?
  • /phpgedview/familybook.php?
  • /phpgedview/hourglass.php?
  • /phpgedview/individual.php?
  • /phpgedview/placelist.php?
  • /phpgedview/pedigree.php?
  • /phpgedview/
  • /favicon.ico
  • /phpgedview/modules_v3/fancy_treeview/css/themes/colors/style.css
  • /phpgedview/modules_v3/googlemap/css/wt_v3_googlemap.css
  • /wp-content/plugins/matomo/app/config/global.ini.php
  • /wp-content/plugins/matomo/app/vendor/matomo/device-detector/regexes/bots.yml
  • /robots.txt
  • www.myancestry.de/informationen-artikel/bookmarks-directories
However, I have no idea how to further isolate the problem.
I can actually rule out one thing: the firewall.
I have been using the architecture as a combination of WordPress, webtress and Ninja Firewall for many years under NS7 without any problems.
Sorry to keep laying one finding on the table after the other, making the thread a bit confusing. But that was the original intention.
Logs
`2024-10-03T00:19:10+02:00 [3:lamp2:apache2-app] 119.13.XXX.XXX - - [02/Oct/2024:22:19:10 +0000] “GET /phpgedview/calendar.php?cal=%40%23DHIJRI%40&day=7&month=SAFAR&year=1126&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T00:31:29+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [02/Oct/2024:22:31:29 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=27&month=MAR&year=1838&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-03T01:18:55+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [02/Oct/2024:23:18:55 +0000] “GET /phpgedview/calendar.php?cal=%40%23DJULIAN%40&day=2&month=AUG&year=1732&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T01:24:28+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX- - [02/Oct/2024:23:24:28 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=19&month=SEP&year=1870&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=F&view=day HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T01:35:35+02:00 [3:lamp2:apache2-app] 166.108.XXX.XXX- - [02/Oct/2024:23:35:35 +0000] “GET /phpgedview/famlist.php?surname=WENDENBURG&ged=MyAncestry.ged&falpha=V&ged=MyAncestry.ged&falpha=N HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T02:09:39+02:00 [3:lamp2:apache2-app] 119.8.XXX.XXX - - [03/Oct/2024:00:09:39 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=14&month=JAN&year=1770&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=year HTTP/1.1” 403 1115 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T02:28:32+02:00 [3:lamp2:apache2-app] 119.8.XXX.XXX- - [03/Oct/2024:00:28:32 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=25&month=JUN&year=1843&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=year HTTP/1.1” 403 1115 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T02:34:50+02:00 [3:lamp2:apache2-app] 49.0.XXX.XXX - - [03/Oct/2024:00:34:50 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=29&month=APR&year=1880&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=year HTTP/1.1” 403 1114 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T02:41:08+02:00 [3:lamp2:apache2-app] 114.119.XXX.XXX- - [03/Oct/2024:00:41:08 +0000] “GET /phpgedview/famlist.php?surname=Winkelmann&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T02:47:25+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:00:47:25 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=8&month=SEP&year=1915&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T03:27:36+02:00 [3:lamp2:apache2-app] 119.8.XXX.XXX - - [03/Oct/2024:01:27:36 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=10&month=AUG&year=1827&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=M&view=day HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T03:48:53+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX- - [03/Oct/2024:01:48:53 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=30&month=MAR&year=1770&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T03:51:29+02:00 [3:lamp2:apache2-app] 183.199.XXX.XXX - - [03/Oct/2024:01:51:29 +0000] “GET /informationen-artikel/bookmarks-directories HTTP/1.1” 403 1118 “http://www.myancestry.de/informationen-artikel/bookmarks-directories” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 OPR/89.0.4447.51”
2024-10-03T03:51:30+02:00 [3:lamp2:apache2-app] 183.199.XXX.XXX - - [03/Oct/2024:01:51:30 +0000] “GET / HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 OPR/89.0.4447.51”
2024-10-03T03:55:59+02:00 [3:lamp2:apache2-app] 166.108.204.23 - - [03/Oct/2024:01:55:59 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=23&month=AUG&year=1857&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T04:03:04+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:02:03:04 +0000] “GET /phpgedview/familybook.php?rootid=I3195&ged=MyAncestry.ged HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-03T04:08:41+02:00 [3:lamp2:apache2-app] 110.238.105.253 - - [03/Oct/2024:02:08:41 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=3&month=JUL&year=1200&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=M&view=year HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T04:14:18+02:00 [3:lamp2:apache2-app] 190.92.XXX.XXX- - [03/Oct/2024:02:14:18 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=9&month=APR&year=1992&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1115 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T04:19:55+02:00 [3:lamp2:apache2-app] 124.243.1XXX.XXX - - [03/Oct/2024:02:19:55 +0000] “GET /phpgedview/hourglass.php?rootid=I2304&show_spouse=0&show_full=1&generations=3 HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T04:36:45+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:02:36:45 +0000] “GET /phpgedview/calendar.php?cal=%40%23DHEBREW%40&day=20&month=TVT&year=5772&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T05:04:50+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX- - [03/Oct/2024:03:04:50 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=29&month=JUN&year=1722&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T05:19:15+02:00 [3:lamp2:apache2-app] 110.238.XXX.XXX - - [03/Oct/2024:03:19:15 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=27&month=NOV&year=1653&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T05:35:49+02:00 [3:lamp2:apache2-app] 51.79.XXX.XXX - - [03/Oct/2024:03:35:49 +0000] “GET /phpgedview/individual.php?pid=I1656%27&ged=MyAncestry.ged HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36”
2024-10-03T05:35:50+02:00 [3:lamp2:apache2-app] 51.79.XXX.XXX - - [03/Oct/2024:03:35:50 +0000] “GET /phpgedview/individual.php?pid=I1656&ged=MyAncestry.ged%27 HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36”
2024-10-03T05:48:01+02:00 [3:lamp2:apache2-app] 124.243.1XXX.XXX - - [03/Oct/2024:03:48:01 +0000] “GET /phpgedview/hourglass.php?rootid=I3902&ged=MyAncestry.ged HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T05:55:14+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:03:55:14 +0000] “GET /phpgedview/famlist.php?surname=FROHB%C3%96SE&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T06:08:34+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:04:08:34 +0000] “GET /phpgedview/famlist.php?surname=Sch%C3%BCtte&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T06:13:34+02:00 [3:lamp2:apache2-app] 47.128.XXX.XXX- - [03/Oct/2024:04:13:34 +0000] “GET /robots.txt HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Linux; Android 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Mobile Safari/537.36 (compatible; Bytespider; spider-feedback@bytedance.com)”
2024-10-03T08:01:20+02:00 [3:lamp2:apache2-app] 190.92.XXX.XXX- - [03/Oct/2024:06:01:20 +0000] “GET /phpgedview/calendar.php?cal=%40%23DHIJRI%40&day=25&month=RABIT&year=1095&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T08:07:00+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX - - [03/Oct/2024:06:07:00 +0000] “GET /phpgedview/famlist.php?alpha=F&ged=MyAncestry.ged&show=surn HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T08:12:41+02:00 [3:lamp2:apache2-app] 159.138.XXX.XXX - - [03/Oct/2024:06:12:41 +0000] “GET /phpgedview/calendar.php?cal=%40%23DHIJRI%40&day=1&month=DHUAQ&year=1263&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T08:32:57+02:00 [3:lamp2:apache2-app] 66.249.XXX.XXX - - [03/Oct/2024:06:32:57 +0000] “GET /phpgedview/tree/MyAncestry.ged/individual/I2873/Vertraulich HTTP/1.1” 403 57498 “-” “Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.6668.70 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)”
2024-10-03T08:41:06+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:06:41:06 +0000] “GET /phpgedview/famlist.php?surname=Merker&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
024-10-03T09:21:16+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:07:21:15 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=3&month=AUG&year=1747&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T09:32:53+02:00 [3:lamp2:apache2-app] 190.92.XXX.XXX- - [03/Oct/2024:07:32:53 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=10&month=APR&year=1843&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T09:44:30+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:07:44:30 +0000] “GET /phpgedview/calendar.php?cal=%40%23DHIJRI%40&day=29&month=MUHAR&year=1104&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-03T09:56:07+02:00 [3:lamp2:apache2-app] 110.238.XXX.XXX - - [03/Oct/2024:07:56:07 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=7&month=FEB&year=1715&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T10:15:07+02:00 [3:lamp2:apache2-app] 119.13.XXX.XXX - - [03/Oct/2024:08:15:07 +0000] “GET /phpgedview/famlist.php?surname=Wendenburg&ged=MyAncestry.ged&falpha=V&ged=MyAncestry.ged&falpha=R HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T11:55:05+02:00 [3:lamp2:apache2-app] 110.238.XXX.XXX- - [03/Oct/2024:09:55:05 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=14&month=OCT&year=1489&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T12:32:52+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX - - [03/Oct/2024:10:32:52 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=26&month=AUG&year=1907&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T12:46:55+02:00 [3:lamp2:apache2-app] 66.249.XXX.XXX - - [03/Oct/2024:10:46:55 +0000] “GET /phpgedview/tree/Schreiber/family/F118/Albert-Gruner-Marie-Purschke HTTP/1.1” 403 47542 “-” “Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.6668.70 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)”
2024-10-03T12:58:18+02:00 [3:lamp2:apache2-app] 190.92.XXX.XXX - - [03/Oct/2024:10:58:18 +0000] “GET /phpgedview/famlist.php?surname=Tappe&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T14:29:20+02:00 [3:lamp2:apache2-app] 119.8.162.110 - - [03/Oct/2024:12:29:20 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=30&month=JUL&year=1314&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=year HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T14:49:11+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:12:49:11 +0000] “GET /wp-content/plugins/matomo/app/config/global.ini.php HTTP/1.1” 403 443 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:131.0) Gecko/20100101 Firefox/131.0”
2024-10-03T14:49:11+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:12:49:11 +0000] “GET /wp-content/plugins/matomo/app/vendor/matomo/device-detector/regexes/bots.yml HTTP/1.1” 403 443 “-” “WordPress/6.6.2; https://www.myancestry.de”
2024-10-03T14:49:53+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:12:49:53 +0000] “GET /wp-content/plugins/matomo/app/config/global.ini.php HTTP/1.1” 403 443 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:131.0) Gecko/20100101 Firefox/131.0”
2024-10-03T14:49:53+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:12:49:53 +0000] “GET /wp-content/plugins/matomo/app/vendor/matomo/device-detector/regexes/bots.yml HTTP/1.1” 403 443 “-” “WordPress/6.6.2; https://www.myancestry.de”
2024-10-03T14:54:22+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:12:54:22 +0000] “GET /wp-content/plugins/matomo/app/config/global.ini.php HTTP/1.1” 403 443 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:131.0) Gecko/20100101 Firefox/131.0”
2024-10-03T14:54:22+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:12:54:22 +0000] “GET /wp-content/plugins/matomo/app/vendor/matomo/device-detector/regexes/bots.yml HTTP/1.1” 403 443 “-” “WordPress/6.6.2; https://www.myancestry.de”
2024-10-03T15:27:29+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX- - [03/Oct/2024:13:27:29 +0000] “GET /phpgedview/famlist.php?surname=Brandt&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-03T15:52:11+02:00 [3:lamp2:apache2-app] 101.44.XXX.XXX - - [03/Oct/2024:13:52:11 +0000] “GET /phpgedview/calendar.php?cal=%40%23DHEBREW%40&day=2&month=CSH&year=5548&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-03T15:58:22+02:00 [3:lamp2:apache2-app] 114.119.XXX.XXX - - [03/Oct/2024:13:58:22 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=17&month=MAY&year=1721&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=M&view=day HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T16:17:27+02:00 [3:lamp2:apache2-app] 49.0.202.15 - - [03/Oct/2024:14:17:27 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=25&month=JAN&year=1903&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1114 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T16:23:55+02:00 [3:lamp2:apache2-app] 101.44.XXX.XXX- - [03/Oct/2024:14:23:55 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=15&month=AUG&year=1828&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=&view=month HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-03T16:49:45+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX - - [03/Oct/2024:14:49:45 +0000] “GET /phpgedview/famlist.php?ged=MyAncestry.ged&surname=Bastian HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36 Edg/101.0.1210.47”
2024-10-03T16:57:25+02:00 [3:lamp2:apache2-app] 183.198.XXX.XXX - - [03/Oct/2024:14:57:25 +0000] “GET /informationen-artikel/bookmarks-directories HTTP/1.1” 403 1118 “http://www.myancestry.de/informationen-artikel/bookmarks-directories” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 Edg/114.0.1264.71”
2024-10-03T16:57:26+02:00 [3:lamp2:apache2-app] 120.11.XXX.XXX- - [03/Oct/2024:14:57:26 +0000] “GET / HTTP/1.1” 403 1115 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 Edg/114.0.1264.71”
2024-10-03T16:57:29+02:00 [3:lamp2:apache2-app] 120.11.XXX.XXX- - [03/Oct/2024:14:57:29 +0000] “GET /wp-login.php?action=register HTTP/1.1” 403 1115 “https://www.myancestry.de” “Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36”
2024-10-03T16:57:30+02:00 [3:lamp2:apache2-app] 183.198.XXX.XXX - - [03/Oct/2024:14:57:30 +0000] “GET /wp-login.php?action=register HTTP/1.1” 403 1118 “Anmelden ‹ myAncestry — WordPress” “Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36”
2024-10-03T17:30:30+02:00 [3:lamp2:apache2-app] 101.44.XXX.XXX - - [03/Oct/2024:15:30:30 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=23&month=OCT&year=1974&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=M&view=day HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-03T17:47:35+02:00 [3:lamp2:apache2-app] 114.119.XXX.XXX - - [03/Oct/2024:15:47:35 +0000] “GET /robots.txt HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (compatible;PetalBot;+https://webmaster.petalsearch.com/site/petalbot)”
2024-10-03T17:54:32+02:00 [3:lamp2:apache2-app] 37.27.37.235 - - [03/Oct/2024:15:54:32 +0000] “GET /robots.txt HTTP/1.1” 403 1114 “-” “Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; Bravebot/1.0; +https://search.brave.com/help/brave-search-crawler) Chrome/W.X.Y.Z Safari/537.36”
2024-10-03T19:15:23+02:00 [3:lamp2:apache2-app] 110.238.XXX.XXX - - [03/Oct/2024:17:15:23 +0000] “GET /phpgedview/famlist.php?surname=RIESEL&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-03T19:41:39+02:00 [3:lamp2:podman] 2024-10-03 19:41:39.217644039 +0200 CEST m=+0.557319425 pod start f5fa405b9d3bc7d60970e3b96881c01d5dcbf02db735f8b24d30fd6646765547 (image=, name=lamp)
2024-10-03T19:43:12+02:00 [3:lamp2:apache2-app] 47.128.XXX.XXX- - [03/Oct/2024:17:43:06 +0000] “GET /robots.txt HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Linux; Android 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Mobile Safari/537.36 (compatible; Bytespider; spider-feedback@bytedance.com)”
2024-10-03T19:43:28+02:00 [3:lamp2:apache2-app] 47.128.24.241 - - [03/Oct/2024:17:43:28 +0000] “GET /robots.txt HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Linux; Android 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Mobile Safari/537.36 (compatible; Bytespider; spider-feedback@bytedance.com)”
2024-10-03T19:44:37+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:17:44:37 +0000] “GET /wp-content/plugins/matomo/app/config/global.ini.php HTTP/1.1” 403 443 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:131.0) Gecko/20100101 Firefox/131.0”
2024-10-03T19:44:37+02:00 [3:lamp2:apache2-app] 89.58.XXX.XXX - - [03/Oct/2024:17:44:37 +0000] “GET /wp-content/plugins/matomo/app/vendor/matomo/device-detector/regexes/bots.yml HTTP/1.1” 403 443 “-” “WordPress/6.6.2; https://www.myancestry.de”
2024-10-03T20:20:39+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX- - [03/Oct/2024:18:20:39 +0000] “GET /phpgedview/ancestry.php?rootid=I1691&ged=MyAncestry.ged HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-04T00:55:30+02:00 [3:lamp2:apache2-app] 111.119.XXX.XXX - - [03/Oct/2024:22:55:30 +0000] “GET /phpgedview/placelist.php?parent%5B%5D=Deutschland&parent%5B%5D=Baden-W%C3%BCrttemberg&parent%5B%5D=Esslingen&ged=MyAncestry.ged&action=show HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-04T01:26:10+02:00 [3:lamp2:apache2-app] 124.243.XXX.XXX - - [03/Oct/2024:23:26:10 +0000] “GET /phpgedview/familybook.php?rootid=I1810&ged=MyAncestry.ged HTTP/1.1” 403 1118 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-04T01:40:33+02:00 [3:lamp2:apache2-app] 166.108.XXX.XXX - - [03/Oct/2024:23:40:33 +0000] “GET /phpgedview/pedigree.php?rootid=I2388&ged=MyAncestry.ged HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”
2024-10-04T02:44:53+02:00 [3:lamp2:apache2-app] 190.92.XXX.XXX - - [04/Oct/2024:00:44:53 +0000] “GET /phpgedview/hourglass.php?rootid=I3778&show_spouse=0&show_full=1&generations=3 HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36”
2024-10-04T03:02:40+02:00 [3:lamp2:apache2-app] 101.44.XXX.XXX - - [04/Oct/2024:01:02:40 +0000] “GET /phpgedview/indilist.php?surname=Ahrend&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-04T04:43:34+02:00 [3:lamp2:apache2-app] 166.108.XXX.XXX - - [04/Oct/2024:02:43:34 +0000] “GET /phpgedview/calendar.php?cal=%40%23DGREGORIAN%40&day=2&month=NOV&year=1727&filterev=BIRT-MARR-DEAT&filterof=all&filtersx=M&view=day HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.67 Safari/537.36”
2024-10-04T05:04:46+02:00 [3:lamp2:apache2-app] 116.90.XXX.XXX - - [04/Oct/2024:03:04:45 +0000] “GET /phpgedview/ HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15”
2024-10-04T05:04:47+02:00 [3:lamp2:apache2-app] 116.90.XXX.XXX - - [04/Oct/2024:03:04:47 +0000] “GET /favicon.ico HTTP/1.1” 403 1116 “https://www.myancestry.de/phpgedview/” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15”
2024-10-04T05:06:44+02:00 [3:lamp2:apache2-app] 116.90.XXX.XXX - - [04/Oct/2024:03:06:44 +0000] “GET / HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15”
2024-10-04T05:07:00+02:00 [3:lamp2:apache2-app] 116.90.XXX.XXX - - [04/Oct/2024:03:07:00 +0000] “GET /phpgedview/ HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15”
2024-10-04T05:10:53+02:00 [3:lamp2:apache2-app] 101.44.XXX.XXX - - [04/Oct/2024:03:10:53 +0000] “GET /phpgedview/indilist.php?surname=Schroeder&ged=MyAncestry.ged&show=indi&show_marnm=yes HTTP/1.1” 403 1117 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36”
2024-10-04T05:14:42+02:00 [3:lamp2:apache2-app] 116.90.XXX.XXX - - [04/Oct/2024:03:14:42 +0000] “GET / HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.0 Safari/605.1.15”
2024-10-04T05:28:27+02:00 [3:lamp2:apache2-app] 101.98.XXX.XXX - - [04/Oct/2024:03:28:27 +0000] “GET / HTTP/1.1” 403 1116 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36”
2024-10-04T05:28:28+02:00 [3:lamp2:apache2-app] 101.98.XXX.XXX - - [04/Oct/2024:03:28:28 +0000] “GET /favicon.ico HTTP/1.1” 403 1116 “https://www.myancestry.de/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36”
2024-10-04T06:36:17+02:00 [3:lamp2:apache2-app] 66.249.XXX.XXX- - [04/Oct/2024:04:36:17 +0000] “GET /phpgedview/modules_v3/fancy_treeview/css/themes/colors/style.css HTTP/1.1” 403 443 “Vorfahrenkarte von Emauel Paul Wendenburg – myAncestry - Genealogie der Familien Bernd, Dargel, Prescher, Klepp, Wendenburg u.a.” “Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.6668.70 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)”
2024-10-04T06:36:24+02:00 [3:lamp2:apache2-app] 66.249.XXX.XXX- - [04/Oct/2024:04:36:24 +0000] “GET /phpgedview/modules_v3/googlemap/css/wt_v3_googlemap.css HTTP/1.1” 403 443 “Vorfahrenkarte von Emauel Paul Wendenburg – myAncestry - Genealogie der Familien Bernd, Dargel, Prescher, Klepp, Wendenburg u.a.” “Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.6668.70 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)”
2024-10-04T06:45:12+02:00 [3:lamp2:apache2-app] 66.249.XXX.XXX - - [04/Oct/2024:04:45:12 +0000] “GET /phpgedview/modules_v3/fancy_treeview/js/tab.js HTTP/1.1” 403 443 “Justina Friederike Günther 1789–… – Stammbaum der Familien Schreiber, Rauch, Jentsch” “Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.6668.70 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)”
