And thanks!
Well, that was easyâŠ
- Create an NS8-LAMP instance and set FQDN and MariaDB password
- Go to phpmyadmin and create a database and user with all privileges on that database
- Set phpmyadmin off in settings
- via node console run ârunagent -m lamp1 podman exec -ti lamp-app bashâ
- Go to â/appâ directory and ârm -f index.phpâ
- Download the latest vvveb from github with: wget https://github.com/givanz/Vvveb/releases/download/1.0.4/latest.zip
- unzip latest.zip
- exit the container console and exit the node console
- Browse to your FQDN and voila, fill out the credentials required and you are in business!
How wonderful and nice POC. Bobâs your uncle!
(Wiki time)
please could you test the backup and restore ![]()
Yeah I wanted something simple for the sysadmin, we do not really think in the same way, dev vs sysadmin
- Installed vvveb CMS, working (lamp3)
- Set backup to local storage and enforce immediate backup. Confirmed
- remove lamp3 via software center â confirm deleted
- Restore â select lamp3 instance with backup just made on local storage
- vvveb CMS restored as lamp4
- lamp4 working as expected, no issues.
ps. Backup for lamp4 has to be set obviously
Nice!
be kind to share tutotial(LAziness speaking)
thank ![]()
5 messages back? ![]()
my bad
Looks total different at me
LAMP 1.0.8.
When I try to open phpmyadmin using the link, the website opens instead.
Using https://FQDN/phpmyadmin too.
I
I cannot reproduce, with an upgrade I messed up something and by default phpmyadmin was disabled hence you get a 404 until you save again the settings page
This has been fixed in 1.0.9
I miss translations, I only push in english
Isnât it possible to have English as a fall back language?
Or a languageâs switcher within the profile?
it is a core function but what I do not understand is I see the english translation even if my locales are french
what is your browser ?
do you have automatic translation to german ?
do you have enabled extensions
Just curious, I see the latest version on github is 1.0.9, and in software center, after refresh, it is not yet available (checked after an hour). What would be the expected repo refresh interval for the newest release be available in Software Center?
Is it the 4 hours mentioned here ?
TIA
I think yes, if you check here, the 1.0.9 is not available
Safari and Firefox
no autmatic translation
Only 1Password Extension
Indeed it takes the 4 hours for the meta data to populate accurate repo info
Works as expected with enable/disable phpmyadmin setting.
