NS8-Guacamole - first testing prerelease
Hi friends,
by using the ns8-kickstart-db templates by @stephdl I was finally able to create my first NS8 module.
If you like to test Guacamole on NS8:
add-module ghcr.io/mrmarkuz/guacamole:working
Just configure the guacamole hostname in the app settings page in cluster admin and browse to https://configured.hostname.tld/guacamole. The default login is user guacadmin, password guacadmin.
Backup/Restore should work already from the template.
Still on the todo list:
  • LDAP/AD bind
  • Branding
  • Remove guacamole path in URL
I am happy :slight_smile:
Congratulations on your first Module @mrmarkuz
I am also very interested in learning how the AD/Ldap Integrations works.
Managed to install successfully, the module is reachable at /guacamole
username and password guacadmin/guacadmin
is this not all i need to conenct to a server
I keep getting this
Woooooooooow
Looks like FOSDEM you did well.
Good job my friend!
@stephdl you have a new promising padawan! :smiley:
I would move it to Development testing and create a new topic once it is released. What do you think @mrmarkuz ?
How to remove the module? (My case 1 node cluster). I tried this:
[root@srv1 ~]# remove-module guacamole:working
<3>Cannot retrieve the NODE_ID of guacamole:working
[root@srv1 ~]# remove-module --help
usage: remove-module [-h] [–no-preserve] [–force] module
positional arguments:
module
options:
-h, --help show this help message and exit
–no-preserve erase also the module home directory
–force unconditionally erase the module from Redis (dangerous)
[root@srv1 ~]#
Reason for removal is that no ldap domains are listed in the settings page.
HTH
remove-module guacamole1
LDAP isn’t implemented yet
Ah, my bad in bad reading :wink:
Anyway, the issue is the following:
  • Installed the module (add-module)
  • Entered the settings FQDN, certificate and HTTPS
  • Save setting
  • go to FQDN entered in settings
Do you really need help to do a simple SSH connection to a server?
All current OS have. a usable SSH client nowadays, even Windows!
Why would any sane person waste more than one persons time trying to run SSH over HTML5 when every OS has SSH?
A Desktop is a different matter, the encryption for any Desktoptransfer with VNC or RDP is not enough, so a VPN is needed. Guacamole makes setting up a VPN redundant.
i think this will preseve some data,
remove-module --no-preserve guacamole1
for complete removal
Using Guacamole, YEs Andy i actually need help, thats why i posted.
Thanks @oneitonitram !
[root@srv1 ~]# remove-module --no-preserve guacamole1
<7>podman rmi --ignore 1238c5206383fd1e698aaa63f8b0ed18efbec1926cf376e511849eaf07d46419
Untagged: Package guacamole · GitHub
Deleted: 1238c5206383fd1e698aaa63f8b0ed18efbec1926cf376e511849eaf07d46419
[root@srv1 ~]#
Looks like you missed the /guacamole path
Ok, let me try again. BUT, I rather have immediate access through the given FQDN without a trailing directory. Just like the Sterling PDF module of @oneitonitram. Simply go to the dedicated subdomain. Very user friendly for for the end user spelling and remembering ‘guacamole’ is a nightmare and has nothing to do with what they want.
They simply want their desktop, hence e.g. https://mypc.mydomain.com :slight_smile:
It’s on the todo list:
I need to RTFM!!
It works as advertised! Thanks!
Please test the brand new Guacamole 1.5.5 app!
The open points were finished:
The LDAP/AD bind is optional.
To be able to install via Software Center you can add my repo.
Installation from CLI:
add-module ghcr.io/mrmarkuz/guacamole:1.0.0-beta.2
Removal:
Documentation is on GitHub.
That is WAY cool!
And works!
And that has been ‘fixed’ too! Very clean URL now. No more “kwakomoloo” typos!
this sounds like an african dialect
@mrmarkuz i dont think you have defined the administrative user while using ldap.
seems guacadmin is still able to login as the defacto admin
under users, i dont see the ldap users, even though they have already loggedin before.
Am i missing something?
Thanks for testing, guys!
You need to give permissions to the ldap users, one method is to create a “domain admins” group as guacadmin, so every LDAP domain admin can login and sees all users/groups.
You can delete the guacadmin user, if you don’t like it to login anymore but it’s a good fallback if LDAP isn’t working.
LDAP is only used for auth, the permissions are stored in postgresql, it was the same for Guacamole in NS7.
It’s documented here.
