I installed DNSMasq out of curiosity. By default it suggest the below. Is the DHCP range correct?
cc @Tbaile
cc @Tbaile
Did you choose the WAN interface? Because there’s not a private IP address…
They are public IP addresses.
They are generated from the choosen network interface. Perhaps you are using it on a VPS?
If your server has multiple interfaces it could perfectly be the case Markus says.
Yep…
Yep…
Sorry for the noise!
So I forgot my own little ‘dummy network’ trick So I created a dummy interface on my 1 node cluster and it is getting me somewhere
So i added some quick NS8 dummy interface notes here:
https://wiki.nethserver.org/doku.php?id=virtual_network_interface#ns8_notes
It’s worth mentioning that the installed module is just for local area networks (LANs); Dnsmasq isn’t intended for cloud environments.
https://docs.nethserver.org/projects/ns8/en/latest/dnsmasq.html#dnsmasq
Why dummy interface?
Because my VPS (Contabo hosted) has only 1 ethernet interface .
