Hi @giacomo
Wow ! Thank you very much.
Is it possible to do something like it for NS8b ?
Michel-André
Hi @giacomo
Michel-André
NS8 already has DNS validation, is built-in inside Traefik: Traefik Let's Encrypt Documentation - Traefik
You can try it by creating a manual config inside /home/trafikX/.config/state/configs.
This is not exposed in the UI because a good web form for it is very very very very hard and time consuming (you can see how many options exists from the link above).
Maybe we can find a way to make it configurable by hand.
@davidep @Amygos what do you think?
I agree we can start with a manual config. However even if a complete UI is not possible, a generic form could be still added to the UI in the future, to avoid falling back to CLI.
Filed a card here in Trello.
Hi @davidep
Just copy it from NethSecurity. (but it will be much better to copy it from OpenWRT because NethSecurity didn’t copy it properly - forgot acme-dnsapi)
For an example, look at: NethSecurity Install on Proxmox shield (doc error) - #14 by michelandre
Michel-André
