Ns8-ddclient v4 needs testers
hello something new to test, some breaking changes has been introduced, for what I tested so far it is workable but who knows.
add-module ghcr.io/stephdl/ddclient:1.0.3-dev.1
It works as expected, tested with ddnss, dynu and goip. The providers showed correct update times. :+1:
When I chose “changeip” as ddclient protocol in the UI I got “porkbun”.
I found that for the last 2 dropdown items the names don’t match to the values:
fixed and released
This is awesome! Thanks for working on this, Stephane. If I were to test it, do I install another instance of ddclient? I wouldn’t want one conflicting with the other. Or do I delete the first and reinstall ddclient?
the upgrade should work but now you have to set the key you have
Good stuff! I didn’t notice there was an update listed for it in my applications list. You added a lot! Thanks!
