NS8 core update 0.0.38 -> 1.0.0 admin UI does not load
NS8 on rocky 9 VM
After core update the Admin UI is not accessible, journalctl shows this error:
node[806]: task/node/1/XXXXXXXXXXXXXXXX: get-info/20read is starting
node[806]: Context set error: NOPERM this user has no permissions to access one of the keys used as arguments
Seems like an issue with Redis ACL and (missing / changed) permissions of the admin user.
Or maybe something with 2FA on admin account (was not enabled in core 0.0.38)
Modules work fine.
I have two questions:
  1. how do I check the running core version from the command line?
  2. Any hints on how to correct this error?
I think there are issues updating from alpha:
Markus is right: for security reasons, we changed some ACLs in the beta 1.
You should reinstall it.
This should not happen anymore on next updates.
