Li**gthS**quid diagnostic.
Error : report folder ‘/var/lightsquid’ not contain any valid data! Please run lightparser.pl (and check ‘report’ folder content)
Please check config file !
Variable value
$tplpatph /usr/share/lightsquid/tpl
$templatename nethesis
$langpatph /usr/share/lightsquid/lang
$langname eng
$reportpath /var/lightsquid
Access to '/var/lightsquid' folder yes
$graphreport 1
folder content:
1st: It had a missspelling LightSquid not LigthSquid
Second: I tried to run lightparser.pl and nothing happen
In my /var/log I just have ./squid & ./squidGuard
no ./ligthSquid or ./lightSquid
squidclamav and squid services are active and running
The only log I could find about this service is this :
****** esmith::event[32552]: Event: nethserver-lightsquid-update SUCCESS
So apparently the update worked.
The misspelled word seems to be from upstream.
Installed webproxy, webfilter, generated some traffic, and the reports showed right after running lightparser.pl
Sorry, I cannot reproduce the problem.
Does it throw any error when running lightparser.pl -d
You will have informations there after midnight.
Till then, you will see this windows.
Please wait till tomorrow.
If I remember well, the logrotate is set to “daily”.
Edit:
And of course, you must have some traffic through proxy.
