Centos 7 minimal
yum install -y http://mirror.nethserver.org/nethserver/nethserver-release-7.rpm
nethserver-install
Starting NethServer installation process. It will take a while...
Installing base system...
Loaded plugins: fastestmirror
One of the configured repositories failed (Unknown),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=<repoid> ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable <repoid>
or
subscription-manager repos --disable=<repoid>
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: nethserver-base/7/x86_64
Could not retrieve mirrorlist http://mirrorlist.nethserver.org/?release=7&repo=base&arch=x86_64&nsrelease=$nsrelease error was
14: HTTP Error 404 - Not Found
or
compromise:
Configuring system, please wait...
Failed to execute operation: No such file or directory
/usr/sbin/nethserver-install: line 45: /sbin/e-smith/signal-event: No such file or directory
You can access the Web interface at:
/usr/sbin/nethserver-install: line 51: /sbin/e-smith/db: No such file or directory
/usr/sbin/nethserver-install: line 52: /sbin/e-smith/db: No such file or directory
https://.:980/usr/sbin/nethserver-install: line 48: /sbin/e-smith/db: No such file or directory
Login: root
Password: <your_root_password>
Installation log can be found here: /var/log/nethserver-install.log
