NS7 not full bandwidth
NethServer Version: 7.3.1611
i just installed NS7 on my ProxMox Node yesterday and i´m very happy with it. But today i noticed that i´m not getting my full 200Mbit/s through it. In an earlier NS6 installation the problem was solved by @filippo_carletti here. I also tried his soloution but it did just helped a little bit.
For now i´m making speedtest with about 160MBit/s.
When i´m running speedtests or download big files the CPU load is at 99%. Pingtimes are about >100ms. In my earlier NS6 installation that was no problem - downloading 2GB with 200Mbit/s and ping google with 8ms. I think this problem is caused by a single process (ksoftirqd).
I also disabled bandwithd but that didn´t helped. Any ideas?
I´m running stable 200Mbit/s speedtests with my older router.
I think that bandwidth is throttled by lack of resources, probably a combination of proxmox and centos network drivers.
You may need to adjust some settings in proxmox. What ethernet drivers are you using?
Could you try to use a different network emulation in the NethServer VM?
Thank you! I will try that…
It´s a little bit complex. If i´m changing network driver in proxmox for the ppp0 network card CentOS is going crazy and doing nothing. I had to copy the config from old interface to the new one. But after that the interface is still not working. I think i will do a complete new installation with other drivers tomorrow.
yep thats it… Working with VirtIO (paravirtualized) driver. Thanks!
Thanks for reply.
Remember to mark “solved” the answer that you think helped you.
Good job :+1:
