NS7 Certificate update problem
NethServer Version: 7.9.2009
I just prolonged let’s encrypt certificates (automatically via certbot) and a manual SSL certificate, but the apache server does not start up any more with fatal error “Failed to configure CA certificate chain!”. When I restore the previous let’s encrpt certificates it works. Has something been changed, so that the (old) apache 2.4.6 does not accept the new certificates?
Any suggestions?
Nothing changed AFAIK, I suspect the manual SSL certificate. Maybe the CA file doesn’t contain the full chain anymore?
To check letsencrypt you could use following command, see also Certificate Management — NethServer 7 documentation
/usr/libexec/nethserver/letsencrypt-certs -h
