NS Cockpit UI is not working properly
NethServer Version: 7.8.2003 (final)
Module: nethserver-cockpit
My NS cockpit UI is not working as it should, this is a screenshot:
As you can see all I got is a “Not Found” message. How can I fix this ?
Just a shot in the dark. I had probs with my cockpit after some false positives were quarantined. Do you have clamscan from Stephane de Labrusse repo installed?
I have clamav install due to using proxy and mail. I don’t know from which repo is installed.
How can I check this ?
You would know, if you would have installed it as you would have activated/installed the repo:
https://wiki.nethserver.org/doku.php?id=clamscan This can be used for scanning content of your fileserver. Thats why I am testing it.
So - probably not the source of your problem I’m afraid. But as I had a similar output of the cockpit interface I thought, I should mention it.
Apparently something is missing. I don’t know if ‘yum install @nethserver-iso’ could reveal missing packages of your nethserver install - maybe worth a try. Else I am out of ideas and leave it to the more experienced users who certainly will chim in and be of more help. :slight_smile:
restart cockpit
systemctl restart cockpit
check in the browser console what is occuring (F12)
check that you have not removed core rpm
I had removed some core rpm package :sweat_smile:. Problem fixed.
Thanks
