I have installed NS 7 beta 2, and I’d like to use it as a PDC. When I try to connect to the domain from win 10 client I get the fallowing error after enterd the administrator user and the password:
my config is:
NS ip: 192.168.111.62
Domain account:
NetBIOS domain name: TEST
LDAP server: 192.168.111.63
LDAP server name: nsdc-nethserver.test.lan
Realm: TEST.LAN
Bind Path: dc=TEST,dc=LAN
LDAP port: 389
Server time: Tue, 11 Oct 2016 13:15:08 CEST
KDC server: 192.168.111.63
Server time offset: 0
Join is OK
I added the NS (192.168.111.62) as a DNS like here:
NS’s DNS table is empty, but the service is running.
No not in your router, sorry that I was unclear.
In your nic-setup. Where from does your machine get its ip? Which one is your dhcp?
This is an example of an static IP-setup.
If your dhcp is i.e. your router, the gateway and dns-server is automatically set to your routers ip. Then your machine can not join, because your router doesn’t know the dns of your testserver/nsdc.
For testpurpose I like static IP, like above. If you don’t want static ip, your testserver has to be the dhcp/dns for the machine to join, because then the gateway and dns is set to your testserver.
Thank you for your answer! For testing purpose I manually configured a static ip, the DNS and the gateway is the NS, but the error message is the same.
if you believe that the problem is solved, marks “solved” the answer that helped you.
This helps anyone looking for the same problem and who responds to the support
Thanks friend
