Ns.1.5.0-rc1 issues
Hello everyone,
I Just upgraded to 24.10.0-ns.1.5.0-rc1
I noticed 2 issues:
I’ve tried DHCP mac binding, but appears not enabled, even after soft binding enabled.
On network scan, i found duplicates ip and Mac address on result list.
I’ve found this problem in 1.4 stable too.
Can you riproduce these 2 issues?
Thank you
No, I couldn’t reproduce.
Soft binding worked: Changed the IP of a DHCP configured device to another manual IP and wasn’t able to browse because of IP/MAC mismatch.
Strict binding worked: A manually configured device not in reservations wasn’t able to browse.
There were no duplicates in the network scan.
This is the command that is used to scan br-lan, does it also show the duplicates?
arp-scan -I br-lan -l -x --macfile=/usr/share/arp-scan/mac-vendor.txt
Sorry but i can’t reproduce duplicates in network scan, now both the suggested command and ui list are correct.
For Mac binding problem, i share a screenshot here.
After enabling soft binding, saving it and applying the changes I get:
It seems you changed the interface/bridge name, maybe that’s an issue?
I can’t Remember, maybe after ns7 migration…
Just solved the problem.
After ns7 migration, DHCP settings were not changing. br0 was the name of the bridge before migration. DHCP enable/disable was broken too.
I deleted and re-created green network interfacce, now Mac binding is working.
