I receive daily a warning like this:
Not using downloaded remi-safe/repomd.xml because it is older than what we have:
Current : Sat Apr 3 06:50:33 2021
Downloaded: Fri Mar 26 09:29:46 2021
how to solve this?
how to solve this?
Maybe you’re getting some cached repo file. Sometimes temporarily fixed with yum clean all
But before that, what is the outcome of these commands?
yum repolist -v remi-safe
curl -I http://rpms.remirepo.net/enterprise/7/safe/x86_64/repodata/repomd.xml
»changelog«-Plugin wird geladen
»fastestmirror«-Plugin wird geladen
»nethserver_events«-Plugin wird geladen
Config time: 0.018
Yum version: 3.4.3
- ce-base: mirrors.ukfast.co.uk
- ce-extras: mirrors.ukfast.co.uk
- ce-sclo-rh: mirrors.ukfast.co.uk
- ce-sclo-sclo: mirrors.ukfast.co.uk
- ce-updates: mirrors.ukfast.co.uk
- epel: mirror.szerverem.hu
- nethforge: repo.nokken.co.uk
- nethserver-base: repo.nokken.co.uk
- nethserver-updates: repo.nokken.co.uk
- remi-safe: mirror.digitalnova.at
- stephdl: stephdl.dargels.de
Paket-Behälter wird eingerichtet
pkgsack time: 0.020
Repo-id : remi-safe
Repo-name : Safe Remi’s RPM repository for Enterprise Linux 7 - x86_64
Repo-status : aktiviert
Repo-Revision: 1617425433
Repo aktualisiert : Sat Apr 3 06:50:33 2021
Repo-pkgs : 4.148
Repo-Größe : 806 M
Repo-Spiegel : http://cdn.remirepo.net/enterprise/7/safe/mirror
Repo-baseurl : Index of /remi/enterprise/7/safe/x86_64 (53 more)
Repo-Verfall : 21.600 Sekunde(n) (zuletzt: Sat Apr 10 05:17:57 2021)
Filter : read-only:present
Paketquellen-Dateiname: /etc/yum.repos.d/remi-safe.repo
and
curl -I http://rpms.remirepo.net/enterprise/7/safe/x86_64/repodata/repomd.xml> HTTP/1.1 200 OK
Date: Sat, 10 Apr 2021 09:34:03 GMT
Server: Apache/2.4.37 (centos) OpenSSL/1.1.1g
Last-Modified: Sat, 10 Apr 2021 05:08:41 GMT
ETag: “c24-5bf974623ac9f”
Accept-Ranges: bytes
Content-Length: 3108
Content-Type: text/xml
That looks good.
Check if you get the same last-modified date with the mirror:
curl -I http://mirror.digitalnova.at/remi/enterprise/7/safe/x86_64/repodata/repomd.xml
Then you can try if it works after yum clean all
Thankyou or your help.
I did not get this error Message today
