EddieA
(Eddie Atherton)
November 22, 2023, 7:06am
1
Saw that there was a couple of updates showing in Software Center, one being a Core update. Hit the button to start the update and went for dinner. Came back to this:
I haven’t tried selecting anything from the context menu yet, in case you need any information before I do a “Cluster Status”.
Cheers.
EddieA
(Eddie Atherton)
November 22, 2023, 8:51am
3
That worked. But the update process should end cleanly. Or is this another “it depends on which version of which browser you are using” issues.
Cheers.
davidep
(Davide Principi)
November 22, 2023, 8:53am
4
I rather think it is a bug,
When we hit such unexpected conditions, we have to attach relevant error messages from the browser console. In Firefox Ctrl + shift + K opens the error console.
It might contain important information for developers to understand and fix the bug.
Edit: filed a bug here (with console dump)
opened 04:40PM - 24 Nov 23 UTC
closed 11:33AM - 28 Dec 23 UTC
bug
verified
The UI enters a freezed state after a Core upgrade
**Steps to reproduce**
In S… oftware Center run upgrade of core from 2.2.0 to 2.2.1 (for instance)
**Expected behavior**
Upgrade is successful and page is refreshed at the end
**Actual behavior**
Page displays some errors and is freezed in loading state
![Image](https://github.com/NethServer/dev/assets/2920838/c45f0771-5073-4673-a498-5b2c00db20d3)
Errors the browser console
https://gist.github.com/DavidePrincipi/c78a43fdab083ce469b345725eb364a7
**Components**
- Core 2.2.0 / 2.2.1
**See also**
See
- https://community.nethserver.org/t/not-sure-if-core-update-has-finished-or-not/22462
- https://community.nethserver.org/t/latest-core-update-stalls-at-84/22594
Thanks to [Eddie Atherton](https://community.nethserver.org/u/EddieA)
