It seems like when I upgraded to 7.6 I have not receiving backup e-mails, cron job e-mails, etc… Basically all the e-mails that used to go to root I have not been receiving, I do get fail2ban e-mails and I have not changed anything am I missing something? I tried searching on line and I have not seen anything regarding the issue.
The last of the admin e-mail aside from fail2ban was 1/6/19 for cron daemon.
You could check the following.
Login as root at the servermanager and click at root@YourFQDN at the upper right corner and select Profile. By external email address has to be your mail address where the root mail should be redirected to.
I didn’t want to send them to another recipient, but the last e-mail was a cronjob alert at 5:06am on 1/6 and nothing after that aside from the fail2ban e-mails.
I see log entries for root@ but then there is a gap from the 6 to the 13th then I continue to see those, but those are fail2ban e-mails. No cron e-mails, backup reports, etc…
When I said I didn’t recall seeing anything I meant I didn’t see any errors.
