Not possible to install clamscan
@Stephdl
Is there a problem with the download of Clamscan?
If I want to install the software, I get this message:
No package nethserver-clamscan available.
Thanks …
Uwe
I believe it is part of nethserver-mail-filter.
http://docs.nethserver.org/projects/nethserver-devel/en/v7/nethserver-mail.html?highlight=virus#nethserver-mail-filter
HTH
Since when should it be like this? So far, I have always been able to install it. Without mail server filter.
Regards…
You can check in Software Center -> Installed -> Packages if there are clamav packages (use CTRL+F in browser and digit “clamav”).
If there isn’t nothing you can install by command
yum install clamav clamav-data clamav-filesystem clamav-lib clamav-server-systemd clamav-unofficial-sigs clamav-update clamd
but I think they’re already configured.
You can find antivirus configuration in Email menu.
Also webfilter menu there is a tab ‘Antivirus’.
It depends what you need.
It’s still available. Maybe the repo is not enabled.
Please try
yum --enablerepo=stephdl install nethserver-clamscan
Wiki page:
https://wiki.nethserver.org/doku.php?id=clamscan
Thanks @mrmarkuz Sorry for the mistake @transocean I was thinking to the other packages that you don’t need.
By the way, I think that Markus solution is what you need.
Regards.
There was a problem with the image on the USB stick. Maybe that was the cause. I downloaded the image again and packed it on a brand new stick. The installation went through cleanly and also the previously uninstallable repo of Stephdl could be installed. After that, the installation of ClamScan also worked. Now I have the problem again that I can not access the cloud function of WebTop as a normal user. But that will be another thread.
Thank you all for the help.
Uwe
