NethServer Version 7.8.2003
I added a DNS entry for duckduckgo safe browsing but cannot edit it any more. Why?
Because you have same entry in DHCP settings.
Here’s an entry without same entry in DHCP:
Here’s my client (that’s using DHCP):
I found the problem: It is a static adress added via “DNS” not DHCP. The display in Nethserver is wrong.
Yes, already fixed. You should find an update in Software Center.
