I tested with Alma 9 cluster on Proxmox and Virtualbox.
When node 2 goes down, node 3 shows no node details:
After starting node 2, node 3 shows the details correctly.
Browser console:
cluster/task/da258311-fa33-4c4d-93ed-e69e3a76cb28
Object { action: "get-cluster-status", data: null, extra: {…}, id: "da258311-fa33-4c4d-93ed-e69e3a76cb28", parent: "", queue: "cluster/tasks", timestamp: "2023-05-21T20:21:50.66642191Z", user: "admin" }
Object { progress: 100, status: "running" }
notification.js:213:14
Object { progress: 100, status: "completed" }
progress: 100
status: "completed"
<prototype>: Object { … }
taskResult get-info
Object { error: "", exit_code: 0, file: "task/node/3/3b8f2c5b-a19b-4f65-963f-231cbba21b4d", output: {…} }
notification.js:231:16
taskResult get-info
Object { error: "", exit_code: 0, file: "task/node/1/2deca2c3-17f7-45e1-9de9-5adecfd0b200", output: {…} }
taskResult get-cluster-status
Object { error: "Error executing task get-info on node/2 Client \"node/2\" was not found\n", exit_code: 0, file: "task/cluster/da258311-fa33-4c4d-93ed-e69e3a76cb28", output: {…} }
node/1/task/4bb17057-9ad3-4541-a065-aef70f5ed031
Object { action: "get-node-status", data: null, extra: {…}, id: "4bb17057-9ad3-4541-a065-aef70f5ed031", parent: "", queue: "node/1/tasks", timestamp: "2023-05-21T20:22:02.110081603Z", user: "admin" }
Object { progress: 0, status: "pending" }
Object { progress: 0, status: "running" }
cluster/task/7fe03d30-17a3-4390-a80b-b87ffcefb297
Object { action: "get-cluster-status", data: null, extra: {…}, id: "7fe03d30-17a3-4390-a80b-b87ffcefb297", parent: "", queue: "cluster/tasks", timestamp: "2023-05-21T19:47:42.83459957Z", user: "admin" }
cluster/task/5d501cc5-955f-4f0e-bfe9-938a3306eb06
Object { action: "get-cluster-status", data: null, extra: {…}, id: "5d501cc5-955f-4f0e-bfe9-938a3306eb06", parent: "", queue: "cluster/tasks", timestamp: "2023-05-21T19:47:47.820488639Z", user: "admin" }
taskResult get-node-status
Object { error: "", exit_code: 0, file: "task/node/1/4bb17057-9ad3-4541-a065-aef70f5ed031", output: {…} }
