Hello community
How do I grant access on the new node SSH (accession before cluster)?
Standard steps according to the instructions:
(Proxmox VM with image NS8-Rocky-Linux-9-NS8-Stable-2.Qcow2)
First start, then logging in by console (password changed), new user created with “Useradd -G Wheel Myuser”, then award this a password with “Passwd Myuser”.
Error message:
“Permission Denied (Publickey, Gssapi-Keyex, GSSAPI-WITH-MIC)”
I then edited the corresponding SSH configs (as usual in other environments) so that I can initially store the key via “SSH-Copy-ID”. Despite the restart of the SSHD and the whole nod, it didn’t work (?)
What is different here or what do I overlook Rockylinux?
Note 1:
With the image I wanted to “practice” the establishment of a cluster (add to the Master Node), but that didn’t work either. The new node indicates me that it would have been successfully joined, on the master it is also climbed, but as “not connected”. Tries several times to start the new node from the image every time and also reset the master after 3 trials to its last snaphot (before the first clustering attempt) and today’s core update to 2.5.1. Not successful.
Note 2:
The masternode is a current on Top Debian installation. I have read that you should avoid mixing different distribution, but it is not that it does not work (and so far it has always been talking about freedom of choice between the distribution below)
Addition:
To determine the cause, I used the provided RockyLinux image as a basis and imported the previous cluster data there (with certain problems, see: https://community.nethserver.org/t/after-a-restore-more-or-old- instances-are-back/22938)
Here too, adding a node was not possible, “success” was reported on the node, the node was displayed on the leader as “added”, but also as “unreachable”.
I tried this several times, always checking and sometimes changing my name definition and resolution (including the leader, of course) - no improvement.
Only when I created a bare NS8 cluster (leader) from the RockyLinux image was I able to add a node. So it works in the lab scenario, but not with my “working data” or the experimental instances that I have tried so far: CrowdSec, Imapsync, Mail, Nextcloud, SOGo, collabora and a Samba AD with a share. In addition, I have set up more than 10 virtual host entries and an SMB repo as a backup.
Note 3:
The image is displayed in the VM with approx. 40GB, but my proxmox host shows me “0”. I didn’t have that with the previous images.
Because of the SSH access, I ask for information on how the usual way in NS8 would be.
The other is more used to report unusual behavior (errors).
Greetings Yummiweb
