Axel
(Axel Urbanski)
1
Hello
I am fiting with the acess to Neth-Freepbx. Cant open Web-Admin including https://192.168.99.12/freepbx server via ipsec from 192.168.38.222 PC.
Result: 403 Forbidden You don’t have permission to access /freepbx on this server.
I can access https://192.168.99.12:980
A PC in the same network 192.168.99.xx had access.
What is to do ?
thx Axel
PS: it is a fresh 7.6 installatin running as a VM in XCP-NG
but is same with 7.5.
no Fail2bin on the Nethserver
mrmarkuz
(Markus Neuberger)
2
By default only the local network is allowed to access freepbx. You may add your VPN network in the server manager:
http://docs.nethserver.org/en/v7/freepbx.html#web-access
It’s possible via command line too:
config setprop httpd-fpbx ValidFrom 192.168.100.0/255.255.255.0
signal-event nethserver-freepbx-httpd-save
Axel
(Axel Urbanski)
3
Hello Markus
thx 4 your support. I am serching on the FreePBx Admin side but its on the Neth Admin side.
Thx 4 help
