[root@nethserver ~]# yum grouplist nethserver-nethmonitor
Loaded plugins: changelog, fastestmirror, nethserver_events, presto
Setting up Group Process
* centos-base: mirror.mirohost.net
* centos-updates: mirror.mirohost.net
* nethforge: nethserver.de-labrusse.fr
* nethserver-base: nethserver.de-labrusse.fr
* nethserver-updates: nethserver.de-labrusse.fr
Available Groups:
Monitoring and inventorying
Done
[root@nethserver ~]# yum groupinstall "Monitoring and inventorying"
Warning: Group nethserver-nethmonitor does not have any packages.
No packages in any requested group available to install or update
I can’t check it right now, I will do tomorrow morning. Thanks for the report!
My bad. I just updated the main mirror.
If you want to try it, use http://packages.nethserver.org/ as your baseurl for nethserver-updates repo.
You must substitute baseurl not mirrorlist.
Example:
[nethserver-updates]
name=NethServer $distroversion updates
baseurl=http://packages.nethserver.org/$distroversion/updates/$basearch/
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-$releasever
enabled=1
enablegroups=1
Otherwise, be patient and wait for the mirror update
No problem! Thank you for reporting, the package group was broken since a while
