NethServer Version: 7.9.2009
Hi guys, how are you?
I hope you’re fine I am a little desperate.
I’m trying to install NethServer using graphical mode: first time everything was ok and there were no problems.
Unfortunately I had to do a clean install again and there the problems began.
I know that if all works as it should when you choose options internet should be already connected thanks for DHCP.
But 90% of the time there was no connection (but network was perfect, I tried to change cables and reboot switch, router, … ) and if I set a static ip address (and toggle the network card switch) seems connected: but it isn’t! If I disconnect cable nothing change.
I tried to install anyway but server is always offline and can’t ping router (or others).
I have found that sometimes the RJ45 port has LED lights turned off.
Finally I tried to make the USB in several ways: Balena Etcher and dd command but situation is the same.
Uff … (Thanks )
Pellegrin A.
