Axel
(Axel Urbanski)
July 24, 2019, 8:41pm
1
NethServer Version: 7.6
Module: Printserver cups
Hello I am installing cups /printserver in my office. Now i want to connect via VPN with http::631and no connect to cups. I want to config the Printers from far via VPN.
I cant try it localy now
What can i do ? Can i add a second network ?
thx axel
robb
(Rob Bosch)
July 24, 2019, 9:07pm
2
Is there a route created from the VPN subnet to the subnet where you have CUPS running?
mrmarkuz
(Markus Neuberger)
July 24, 2019, 11:19pm
3
If VPN and CUPS are not on the same machine, you have to add the VPN network to the trusted networks on the CUPS machine.
http://docs.nethserver.org/en/v7/base_system.html#trusted-networks
Axel
(Axel Urbanski)
July 25, 2019, 5:21am
4
Hello Markus thx 4 help now i had connect to cups
