No access into meshcentral possible
NethServer Version: 7.9.2009
Module: meshcentral
Hi@all,
I just installed meshcentral on a Nethserver DC as described in mr.markuz’s instructions. The installation worked fine. The connection to AD/LDAP is configured. The login page is accessible. LE certificate is also adjusted. But after entering the login data it does not go further. Instead of a correct login I get this message:
Screenshot 2021-10-27 105902
I have checked everything again and compared it with the tutorial from mrmarkuz. Everything looks fine. Where is the error?
Regards…
Uwe
Maybe you need to run
signal-event nethserver-meshcentral-update
once more to setup the proxy correctly.
Are there errors in /var/log/messages or /opt/meshcentral/meshcentral-data/mesherrors.txt ?
Please share the meshcentral config:
config show meshcentral
Mesherror.txt
-------- 10/27/2021, 10:52:02 AM ---- 0.9.39 --------
ERROR: MeshCentral Intel(R) AMT server port 4433 is not available.
-------- 10/27/2021, 10:53:10 AM ---- 0.9.39 --------
events.js:174
throw er; // Unhandled ‘error’ event
Error [ERR_TLS_CERT_ALTNAME_INVALID]: Hostname/IP does not match certificate’s altnames: Host: nsdc-dc01.ad.xxx.de. is not in the cert’s altnames: DNS:ad.xxx.de, DNS:dc01.xxx.de, DNS:remoteaccess.xxx.de
at Object.checkServerIdentity (tls.js:254:17)
at TLSSocket.onConnectSecure (_tls_wrap.js:1098:27)
at TLSSocket.emit (events.js:198:13)
at TLSSocket._finishInit (_tls_wrap.js:666:8)
Emitted ‘error’ event at:
at LdapAuth._handleError (/opt/meshcentral/node_modules/ldapauth-fork/lib/ldapauth.js:185:8)
at Client.emit (events.js:198:13)
at Backoff. (/opt/meshcentral/node_modules/ldapjs/lib/client/client.js:1038:12)
at Backoff.emit (events.js:198:13)
at Backoff.backoff (/opt/meshcentral/node_modules/backoff/lib/backoff.js:41:14)
at /opt/meshcentral/node_modules/ldapjs/lib/client/client.js:1022:15
at f (/opt/meshcentral/node_modules/once/once.js:25:25)
at TLSSocket.onResult (/opt/meshcentral/node_modules/ldapjs/lib/client/client.js:812:7)
at Object.onceWrapper (events.js:286:20)
-------- 10/27/2021, 10:53:28 AM ---- 0.9.39 --------
events.js:174
-------- 10/27/2021, 10:54:24 AM ---- 0.9.39 --------
events.js:174
-------- 10/27/2021, 10:57:44 AM ---- 0.9.39 --------
events.js:174
-------- 10/27/2021, 10:58:15 AM ---- 0.9.39 --------
events.js:174
Error [ERR_TLS_CERT_ALTNAME_INVALID]: Hostname/IP does not match certificate’s altnames: Host: nsdc-dc01.xxx.de. is not in the cert’s altnames: DNS:ad.xxx.de, DNS:dc01.xxx.de, DNS:remoteaccess.xxx.de
-------- 10/27/2021, 11:11:47 AM ---- 0.9.39 --------
events.js:174
-------- 10/27/2021, 11:13:14 AM ---- 0.9.39 --------
events.js:174
-------- 10/27/2021, 11:20:24 AM ---- 0.9.39 --------
events.js:174
-------- 10/27/2021, 11:38:44 AM ---- 0.9.39 --------
events.js:174
Config:
[root@dc01 ~]# signal-event nethserver-meshcentral-update
[root@dc01 ~]# config show meshcentral
meshcentral=service
AgentAllowedIP=
LoginPicture=
MailFrom=xxx
MailHost=xxx.xxx-online.com
MailPort=587
MailTLS=enabled
MailValidation=disabled
TCPPort=8989
Title=
Title2=
TitlePicture=
UserAllowedIP=
VirtualHost=remoteaccess.xxx.de
WANOnly=disabled
access=
ldap=enabled
status=enabled
Hm, Meshcentral checks the cert of the Nethserver DC.
You have two possibilities, allow less secure auth or copy the LE cert to the DC.
Actually, the update of the certificates in the Samba container should work automatically. I installed the script that does the update during setup.
You need to add nsdc-dc01.ad.xxx.de to the letsencrypt cert.
Live can be so simple…
Thank you!
@mrmarkuz
Hi Markus
Had the same issue, but Uwe was faster posting.
The solution worked for me too!
Thx!
