NGINX ssl certificate problem
Nethsecurity 8
Module: NGINX
NGINX ssl certificate problem and it does not load the graphical interface through https://IP:9090, nor does it activate the Luci interface.
The following error is generated:
nginx -T -c ‘/etc/nginx/uci.conf’
2026/01/29 13:15:03 [emerg] 51345#0: cannot load certificate key “/etc/nginx/custom_certs/HTCPark.key”: PEM_read_bio_PrivateKey() failed (SSL: error:1E08010C:DECODER routines::unsupported:No supported data to decode. Input type: PEM)
nginx: configuration file /etc/nginx/uci.conf test failed
Is there a way to regenerate the certificate for Nginx?
Cordially,
Juan Carlos Ortiz Lemos
It seems you uploaded a custom cert/key which has a wrong format.
You could change the affected host rules in the nginx config (/etc/config/nginx) and replace the wrong cert/key with the default one:
	option uci_manage_ssl 'self-signed'
	option ssl_certificate '/etc/nginx/conf.d/_lan.crt'
	option ssl_certificate_key '/etc/nginx/conf.d/_lan.key'
To apply the config:
nginx-proxy-gen
/etc/init.d/nginx restart
See nginx | NethSecurity for more information.
