NethServer Version: 7.8 and 7.9
Module: NFS
Hello everybody
is my understanding write, that a NFS pack is supported but not the configuration in cockpit ?
will be a nice option
Module: NFS
Hello everybody
hello
Thank to my last sponsor corona virus, I got time last spring to bring all my modules to cockpit
However I did not implemented the shared folder creation, so first create a shared folder then go to NFS to enable the nfs support inside
Hello Stephane
thx for fast answer. I did not install NFS yet. There ist no package in the Cockpit Software center. I will try it by the terminal.
https://wiki.nethserver.org/doku.php?id=nfs
it looks like the NFS packages are missing ??
> `[root@neth ~]# yum install nfs-utils nfs-utils-lib
> Loaded plugins: changelog, fastestmirror, nethserver_events
> Determining fastest mirrors
> * ce-base: mirror.netweaver.uk
> * ce-extras: mirror.netweaver.uk
> * ce-sclo-rh: mirror.netweaver.uk
> * ce-sclo-sclo: mirror.netweaver.uk
> * ce-updates: mirror.netweaver.uk
> * epel: ftp-stud.hs-esslingen.de
> * nethforge: repo.nokken.co.uk
> * nethserver-base: repo.nokken.co.uk
> * nethserver-updates: repo.nokken.co.uk
> Package 1:nfs-utils-1.3.0-0.68.el7.x86_64 already installed and latest version
> No package nfs-utils-lib available.
> Nothing to do
> [root@neth ~]# yum install nethserver-nfs
> Loading mirror speeds from cached hostfile
> No package nethserver-nfs available.
> Error: Nothing to do`
yum install http://mirror.de-labrusse.fr/NethServer/7/x86_64/nethserver-stephdl-1.1.7-1.ns7.sdl.noarch.rpm
yum install nethserver-nfs --enablerepo=stephdl
a second source
thx i will try it soon.
Yep module developers get their own repository like me
now there is a part for NFS in Apps nice ![]()
