I would like to put nextcloud data folder on a separate logical volume. Is there a suggested “proper” way to do that so future updates won’t break?
I thought about two approaches:
Mount the new LV to /srv/nextcloud and create a symlink in /var/lib/nethserver to it. or
Mount the nextcloud LV directly to /var/lib/nethserver/nextcloud
Or any other (better) way to accomplish the goal.
That’s right, you need to manually recreate that partition / mount.
Only than would a full restore work.
Maybe this can be improved…
That’s one of the reasons i like virtualizing my servers, like NethServer. Almost online enlargement of Disks, usually only quick reboot needed, and the disk is larger. Big advantage: all is in one piece. NethServer can handle the backups and restore as usual, no changes there.
The reason for separate partition is that I give my users way more quota than I have disk space. If they decide to fill it up I might end with full root partition. I have really bad experience with full XFS root partitions ultimately destroying the whole filesystem. Never want to experience that again.
Everybody choose it’s own poison…
I see the needs you’re speaking about, but jeopardize a full server for make people happy (people who don’t buy bigger disk) it seems not a good choice.
