NethServer Version: 7.9 fully updated april 9th 2021 Module: latest nextcloud available through yum
Hi all,
what would be the best (if possible at all) way to authenticate in Nextcloud against a remote imap server (in this case gmail)
I want to be able that users with a gmail account on a corp domain can authenticate against Nextcloud via email/ password of that gmail account, and that from there the corp domain email is used to and from messages within Nextcloud.
I saw some old Github auth methods (against a own imap server), but I fail. So first I would like to know if it is possible, then how.
That would require enough customization that you’d probably be better off with a manual installation of Nextcloud, rather than the Nethserver packages–that way you wouldn’t see your customization undone with a template expansion.
With that said, if you want to use IMAP, the docs here would seem to be relevant:
Were it up to me, I’d probably be looking at using OpenID Connect instead, which would implement SSO through Google.
I am trying with the build in user backend mechanism, but I wonder in general how to cope with gmail accounts that have a 2FA enabled, and most of them if not all are. For instance, when I log in into my personal hmail account, I have to approve the attempt on my cell phone.
I can’t find anything in any log (messages as well as nextcloud log)
