I followed the instructions. Nextcloud seems to work.
In Security & Setups Warning I have the following new message:
This instance is missing some recommended PHP modules. For improved performance and better compatibility it is highly recommended to install them.
dnutan
(Marc)
March 21, 2020, 12:13pm
22
yum install rh-php73-php-imagick
(which will install sclo-php73-php-pecl-imagick package).
It’s one of the install requirements of our current nextcloud build with php72. If nextcloud is upgraded to use php73 it shall work “out of the box”.
stephdl
(Stéphane de Labrusse)
March 21, 2020, 1:21pm
24
thank to monitor and report if nextcloud will work or fail with rh-php73
mrmarkuz:
Installation:
yum install http://mrmarkuz.goip.de/mirror/devtest/nethserver-rh-php73-php-fpm-0.0.1-1.2.gd07a0b6.ns7.noarch.rpm
I just edited /etc/httpd/conf.d/zz_nextcloud for testing but you may consider using a custom template. Don’t forget to undo these changes when the module is released.
<FilesMatch \.php$>
# SetHandler "proxy:unix:/var/run/rh-php72-php-fpm/nethserver-nextcloud-php72.sock|fcgi://localhost/"
SetHandler "proxy:fcgi://127.0.0.1:9003"
</FilesMatch>
if i had followed these instructions.
do i now undo and follow
stephdl:
yum install nethserver-rh-php73-php-fpm --enablerepo=nethserver-testing
cp /etc/opt/rh/rh-php72/php-fpm.d/000-nextcloud.conf /etc/opt/rh/rh-php73/php-fpm.d/000-nextcloud.conf
modify inside /etc/opt/rh/rh-php73/php-fpm.d/000-nextcloud.conf all references of php72 to php73
then go to /etc/e-smith/templates/etc/httpd/conf.d/zz_nextcloud.conf/10base and modify
to
SetHandler "proxy:unix:/var/run/rh-php73-php-fpm/nethserver-nextcloud-php73.sock|fcgi://localhost/"
then
systemctl restart rh-php73-php-fpm
signal-event nethserver-nextcloud-update
these instructions instead?
on the
installation command. is this version much more diferent than
this version?
mrmarkuz
(Markus Neuberger)
March 22, 2020, 3:00am
26
Yes, please undo and follow the instructions of @stephdl
The module versions are the same (0.0.1-1.2.gd07a0b6)
after implementing the said changes, i am getting error 503 when trying to access nextcloud
mrmarkuz
(Markus Neuberger)
March 22, 2020, 5:55am
28
Hm, it’s working here.
Do you find errors in /var/log/messages ?
Did you edit /etc/opt/rh/rh-php73/php-fpm.d/000-nextcloud.conf and replace php72 with php73?
listen = /var/run/rh-php73-php-fpm/nethserver-nextcloud-php73.sock
;Logs
php_admin_value[error_log] = /var/opt/rh/rh-php73/log/php-fpm/error-nextcloud.log
If not already done install imagick as recommended here and restart the services.
Please post your /etc/httpd/conf.d/zz_nextcloud.conf and /etc/opt/rh/rh-php73/php-fpm.d/000-nextcloud.conf if does not work.
mrmarkuz:
php73.sock
this is hwere the error was. it had php72.sock
stephdl
March 22, 2020, 9:31am
30
for the record all your modification should be upgraded automatically if we move nextcloud to rh-php73
