NethServer Version: NethServer release 7.5.1804
Module: nextcloud
hi all
i have an issue to connect to next cloud using the client software on pcs connected to the nethserver . it give me the following error: ERR_CERT_AUTHORITY_INVALID.
ny way to fix this??? other than not enforcing https???
Which kind of certificate is in use (self-signed, letsencrypt…)?
How the client software is connecting to Nextcloud, with the FQDN or by IP?
Is there any antivirus or security suite interfering?
sorry for late reply. the issue were the downloaded version of nextcloud was beta version from the website.
when i install the stable version the issue were gone. i hope this will be fixed later for the beta client
