Greetings, after a recent upgrade of Nextcloud, I am now receiving this email message once every 5 minutes when the cron for Nextcloud runs.
PHP Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 20480 bytes) in /usr/share/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php on line 133
I have rebooted the server just in case there was any kind of cached issue, that seems not to have fixed anything. I’ve also attempted to adjust the actual memory limit, both in the cron or the configuration, no dice.
But I’m literally getting emails every 5 minutes and it’s driving me insane! Anyone else having this problem or is it just me?
APCu is disabled by default on CLI which could cause issues with nextcloud’s cron jobs. Please make sure you set the apc.enable_cli to 1 on your php.ini config file or append --define apc.enable_cli=1 to the cron job call.
If it’s breaking the cron job for this user, it probably is (or will) for others, so I don’t think I’d want to wait for the next NC release–but before we’d release, might want to also see what’s going on with the database issue mentioned up-topic, in case it also needs a fix in the package.
The Cronjob issue is solved (that APC modification to the cronjob solved it). The big issue now is this mystery service that is now stopping backups. What do I do about that?
