Nextcloud appstore errors - related to IPv6
Nextcloud - 19.0.3
NethServer - 7.8.2003
Hello @support_team,
I’ve noticed today for the first time errors in my Nextcloud warning messages related to accessing the App Store:
Could not connect to appstore: cURL error 7: Failed to connect to 2a01:4f8:130:32f1::53: Network is unreachable (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)
I can’t access my apps anymore in Nextcloud and overall I see a performance decrease in opening my OnlyOffice Apps and accessing files and folders.
The error in the Nextlcoud Logging seems to point to IPv6 - 2a01:4f8:130:32f1::53: Network. Please correct me if I’m wrong.
I don’t use IPv6. Is there a way to disable this in Nethserver or Nextcloud so this warning can stop?
Any other ideas of what is causing this slowness are welcome.
Thank you.
Hi Charles,
I think the Nextcloud app server (page) has problems.
If I browse to apps.nextcloud.com there’s a timeout.
If I browse to apps.nextcloud.org I get a cert problem.
apps.nextcloud.com seems too work again…
Hello @mrmarkuz,
I believe you are correct. The errors are not there today. Thanks for your commenting on my post!
Cheers!
Where do I publish the file in .org?
Sorry, I don’t get it. Which file do you want to publish?
Hi Markuz sorry but with google translate I often struggle to understand the questions in the posts. Ignore what I have written and thanks anyway.
