Hi @stephdl
I would like to report the same effect (Collabora neu installed).
And best wishes for the season!
Hi @stephdl
fun, nothing in logs @Andy_Wismer
Salut @stephdl
What logs exactly do you need - and where do I find them?
I am aware about the âlogsâ section. I should be able to retrieve them there.
I think what we need to understand is why it does not work when in nextcloud you try to access to collabora to edit a file, so do it and check journald
journalctl -f
however do you have enable lets encrypt for both collabora and nextcloud ?
Salut @stephdl
Yes, I have LE enabled for both.
To be honest, the first time I activated Collabora without LE (forgot it) but NextCloud has always used LE.
I changed LE for Collabora, LE is now good.
But the App opens up and starts loading the file, but never finishes rotating / loading.
Now, I canât even open the Collabora Console:
The site resolves correctly:
172.25.90.20 is my NS8 (awr9-ns8)âŠ
LE looks goodâŠ
But a whole load of errors - probably due to the LE mistake I made and later correctedâŠ
Errors are shown in the Log of CollaboraâŠ
What do you think?
Worth it to remove Collabora and reinstall it?
Or track the issue?
yes but the concern is a collabora dns error, reinstall and try to ask for a new dns name, maybe LE is confused
collabora2.domain.com must be a real dns A record at your dns provider to request a letâsencrypt certificate
This is correct, LE provides no error when creating one.
Collabora is an âAâ record on my internal DNS (It is also on my external DNS, there as a CNAME.)
But I also see this in Nextcloud:
Your browser has been unable to connect to the Collabora server: https://collabora.r9.anwi.ch
This URL is determined on the Collabora server either from the configured URL or the server_name parameter in coolwsd.xml.
It did connect, the first days after I enabled LE, but would not work.
I will attempt a reinstall of Collabora - a VM in Proxmox can easily be backupped quickly and restored in worst case. With PBS this is fast.
I will attempt this over lunch, this is my home server, so no issues.
But until lunch, I still need to do some work! ![]()
Exceerpts from the Collabora log:
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] Server: COOLWSD HTTP Server 24.04.7.1
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] Upgrade: websocket
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] Connection: Upgrade
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] Sec-WebSocket-Accept: IksVnKNBm3o03ToWP/op6vpJqrM=
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] | net/WebSocketHandler.hpp:990
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] wsd-00001-00022 2024-12-30 09:38:10.570936 +0000 [ prisoner_poll ] TRC #17: Wrote 201 bytes of 201 buffered data| net/Socket.hpp:1489
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] Ready to accept connections on port 9980.
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] wsd-00001-00001 2024-12-30 09:38:10.571078 +0000 [ coolwsd ] TRC Have 1 new children.| wsd/COOLWSD.cpp:4430
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] wsd-00001-00001 2024-12-30 09:38:10.571105 +0000 [ coolwsd ] INF WSD initialization complete: setting log-level to [warning] as configured.| wsd/COOLWSD.cpp:4445
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] wsd-00001-00001 2024-12-30 09:38:10.572717 +0000 [ coolwsd ] WRN Waking up dead poll thread [main], started: false, finished: false| net/Socket.hpp:724
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] frk-00023-00023 2024-12-30 09:38:10.573947 +0000 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:557
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] frk-00023-00023 2024-12-30 09:38:10.581174 +0000 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:557
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] kit-00033-00033 2024-12-30 09:38:10.582090 +0000 [ kit_spare_002 ] WRN Security warning: running without chroot jails is insecure.| kit/Kit.cpp:3315
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] frk-00023-00023 2024-12-30 09:38:10.589285 +0000 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:557
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] kit-00034-00034 2024-12-30 09:38:10.590985 +0000 [ kit_spare_003 ] WRN Security warning: running without chroot jails is insecure.| kit/Kit.cpp:3315
2024-12-30T10:38:10+01:00 [1:collabora1:collabora] kit-00035-00035 2024-12-30 09:38:10.605218 +0000 [ kit_spare_004 ] WRN Security warning: running without chroot jails is insecure.| kit/Kit.cpp:3315
The reason for suggesting a reinstall is the fact that I have not seen the read-only issue elsewhere (other servers, ForumâŠ).
I will provide more info around 13:00âŠ
once installed and configured you can join the URL and display OK with a valid dns certificate, you can also join the admin page
Some can use collabora without real certificate but I prefer to state ask for a LE certificate
LE is so easy, I also prefer using LE!
Feedback will be comingâŠ
Salut @stephdl
I reinstalled Collabora (now as collabora2) and I can now login into the console.
NextCloud can not connect, it shows me:
Es konnte keine Verbindung zum Collabora Online-Server hergestellt werden.
Failed to connect to the remote server: cURL error 60: SSL peer certificate or SSH remote key was not OK (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://collabora.r9.anwi.ch/hosting/discovery
Nextcloud wonât open any more, seems to need a reconfiguration.
It did request the CODE server name.
Iâm now rebootingâŠ
Salut @stephdl
Finally success!
Nextcloud opens, and so does CODE inside NextCloud - it all works now!
Thanks!
For you and the dev team, all my best wishes for 2025!
super 2 vs 1
@transocean you have to retry again ![]()
Salut @stephdl
As part of the Xmas present I now have a Nr2 on my back⊠(collabora2)
So what, it works!
Hi @stephdl
unfortunately, I canât contribute anything more at the moment because I switched to Onlyoffice from @mrmarkuz to narrow down the error. I will continue to use it for the time being. But thanks for your efforts anyway
RegardsâŠ
Uwe
No problem, BTW I never tested only office, I should have a go one day
I already had it on the NS7. Apart from one or two difficulties, it has always worked reliably. But @mrmarkuz is like you and a few others here, is always a great supporter.
